Old Yeller let me down today
Old 01-25-2016, 12:03 AM
68fish's Avatar
68fish
68fish is offline
I drive my truck everywhere without a hiccup until today.
Of course yesterday symptoms showed themselves.
While doing a couple of bike pickups I noticed my mileage dropped from a normal 18.5 MPG (for me) and I had to put 5 gallons in when I should have had enough for the day. That and the smell of gas made me have a look this morning before taking off. Nothing out of the ordinary so off I go.
5 miles later while getting off the freeway it stalled out. I restarted with a lot of cranking and my foot to the floor due to a stronger gas smell. Got her going and went the 2 blocks to the shop and shut her off. Here is what I found.
Gas streaming out of the lower section of the carb parallel with the butterfly valve and down onto the exhaust manifold . When restarted the gas vanished while running but the engine would not idle, bog down and die and out the gas would flow
Things I observed over time:
Engine always hard to start when hot that requires extended cranking.
Mechanical fuel pump delivers unusually high pressure (to me) because when I replaced the fuel hose a couple months ago I was surprised of the amount of fuel that sprayed out when I took off the hose.
Engine is a 300/6 in a 1970 F100.
Carter carb with auto choke.
Wadda Ya think?
Old 01-25-2016, 02:11 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
I would guess that the higher fuel pressure would be caused by a restriction of some kind. Just like putting your thumb on the end of a garden hose, pressure goes up. But I don't know for certain. But that big yellow truck looks sad on that wrecker.
Old 01-25-2016, 08:23 AM
orich's Avatar
orich
orich is offline
The normal fuel PSI is like 4-6 lbs so you should get a good amount if the vehicle carb float needle valve is good an holding.
It sounds like the carb accelerator pump diaphragm is leaking. Time to rebuild it or have it done is best. A loco Box store you never know if you'll get a keeper the first time.
You may get away with just replacing the accelerator pump diaphragm. But if the carb has never been rebuilt as fas as you know then, I'd say it's time for a complete overhaul on the carb.
Orich
Orich
Old 01-25-2016, 08:41 AM
Gembone's Avatar
Gembone
Gembone is offline
sounds like what my carb did after something went wrong with a rebuild. It was like a fuel fountain! Definitely start with a carb rebuild.
Old 01-25-2016, 10:25 AM
68fish's Avatar
68fish
68fish is offline
Well I can't blame anyone else on the rebuild. I did it over a year ago.
Thanks for the tip on the accelerator pump. I'll look there first.
Old 01-26-2016, 12:48 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
If you wiped an extra coating of something on the gasket there that coating could have given way. If there is a restriction as mentioned above the pressure could be higher than the needle and seat can handle to shut off fuel flow. Or the float sank and it's got gas inside of it. The needle and seat are above the float.
Old 01-26-2016, 03:33 PM
68fish's Avatar
68fish
68fish is offline
My leak is down at the bottom a
I'll try to open it up tonight
I'll keep you updated
Old 01-26-2016, 08:07 PM
68fish's Avatar
68fish
68fish is offline
Put a new accelerator pump unit in along with a new rubber tipped float needle.
It idles nice but still flows fuel after shutdown
I don't want to buy a new carb but I'm stumped.
I wanted to pick up my next bike project tonight but I might miss out on it.
Old 01-26-2016, 08:49 PM
orich's Avatar
orich
orich is offline
What did you set the float setting at ? it may be to high.
Orich
Old 01-26-2016, 09:15 PM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
Might have a piece of crude in the needle and seat from when you replaced the fuel line.I have seen it happen on a 2 barrel carb.
Old 01-26-2016, 11:31 PM
68fish's Avatar
68fish
68fish is offline
Float level good.
I'll check the seat tomorrow.
Thanks
Old 01-27-2016, 07:17 AM
orich's Avatar
orich
orich is offline
Float level good.
Thanks
A few pictures would help where the leak is as this is kind of a guessing game not seeing ..
Orich
Old 01-27-2016, 01:31 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Orich
I think he's talking about where the 9516 gasket is in my pic above Rich. The only thing I can think of is there is either a crack or a porous spot in the carb body that makes it look like that 9516 gasket is leaking.
Old 01-27-2016, 05:49 PM
orich's Avatar
orich
orich is offline
Wonder if gas is wicking out the 9581 shaft like when they get warn to much.
I've only rebuilt one of these about 20 yrs ago. an can't think of other then a high float or acc. pump leaking..
Orich
Old 01-27-2016, 09:37 PM
68fish's Avatar
68fish
68fish is offline
Alrighty then. It's always the simple stuff!
Pulled it apart again and this time looked where the float needle seat screws into the carb top. A whole lot of crap was stuck in there so when there was fuel pressure it would keep the needle from seating. Cleaned it up and problem solved.
Sorry to waste everybody's time with something I should checked first.
Live and learn.
Quick Reply: Old Yeller let me down today
