Old Yeller let me down today
I drive my truck everywhere without a hiccup until today.
Of course yesterday symptoms showed themselves.
While doing a couple of bike pickups I noticed my mileage dropped from a normal 18.5 MPG (for me) and I had to put 5 gallons in when I should have had enough for the day. That and the smell of gas made me have a look this morning before taking off. Nothing out of the ordinary so off I go.
5 miles later while getting off the freeway it stalled out. I restarted with a lot of cranking and my foot to the floor due to a stronger gas smell. Got her going and went the 2 blocks to the shop and shut her off. Here is what I found.
Gas streaming out of the lower section of the carb parallel with the butterfly valve and down onto the exhaust manifold . When restarted the gas vanished while running but the engine would not idle, bog down and die and out the gas would flow
Things I observed over time:
Engine always hard to start when hot that requires extended cranking.
Mechanical fuel pump delivers unusually high pressure (to me) because when I replaced the fuel hose a couple months ago I was surprised of the amount of fuel that sprayed out when I took off the hose.
Engine is a 300/6 in a 1970 F100.
Carter carb with auto choke.
Wadda Ya think?
Wadda Ya think?
on
The normal fuel PSI is like 4-6 lbs so you should get a good amount if the vehicle carb float needle valve is good an holding.
It sounds like the carb accelerator pump diaphragm is leaking. Time to rebuild it or have it done is best. A loco Box store you never know if you'll get a keeper the first time.
You may get away with just replacing the accelerator pump diaphragm. But if the carb has never been rebuilt as fas as you know then, I'd say it's time for a complete overhaul on the carb.
Orich
Orich
Orich
Orich
I think he's talking about where the 9516 gasket is in my pic above Rich. The only thing I can think of is there is either a crack or a porous spot in the carb body that makes it look like that 9516 gasket is leaking.
Alrighty then. It's always the simple stuff!
Pulled it apart again and this time looked where the float needle seat screws into the carb top. A whole lot of crap was stuck in there so when there was fuel pressure it would keep the needle from seating. Cleaned it up and problem solved.
Sorry to waste everybody's time with something I should checked first.
Live and learn.
Live and learn.
