air intake
Old 01-24-2016, 05:04 PM
Marioj87's Avatar
Marioj87
Marioj87 is offline
air intake
i want to upgrade my 2006 f150 fx4 in take. do any of you have an after market intake installed? and has it improved the mileage or do you feel and difference from? what is a good brand for one.
thanks for reading.
Old 01-24-2016, 07:24 PM
wrvond's Avatar
wrvond
wrvond is offline
You will experience much faster acceleration due to the weight savings from your lightened wallet.
The stock air intake is as good as any and better than most after market air intakes.
Old 01-24-2016, 09:24 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
all of the aftermarket units will look pretty, and SUCK hot air in from under the hood.. This will reduce the HP and mileage as compared to stock.......... buy it does look pretty !
Old 01-26-2016, 08:12 PM
tbear853's Avatar
tbear853
tbear853 is offline
Received 1,288 Likes on 1,089 Posts
Not all!
The "Gotts Mod" is the cheapest way that actually accomplishes anything .... and it's what I would have done had the original owner of my truck not already spent good $$$ on the True Flow 20502 air intake. Shortly after I bought the truck in 2009, I came across a discarded OEM complete intake set and swapped it on ..... and very soon swapped back. The OEM has a very restricted looking section in the hose as well as the part that clips in the fender inner wall. The True Flow eliminates both and to me, just "seemed" to have better mid / upper range response but maybe it was just my imagination .... but I will keep it (maybe I just like how it looks right on it?). I do have a tuner and cat back exhaust.
Old 01-26-2016, 09:09 PM
steve(ill)'s Avatar
steve(ill)
I have done the GOTTS mod as the factory horn does appear restricted. Cant say that it helps mileage or acceleration, but it does seem like it would allow more air into the system.......... that being said, the truck normally runs at 2000 RPM, not 6000 RPM. Factory probably has plenty of air at highway speeds ........ but I still like the mod.
Your "aftermarket" is similar also and at least it still has "cold air inlet" as compared to most of the el-cheap-o unit.
Old 01-29-2016, 08:47 PM
tbear853's Avatar
tbear853
tbear853 is offline
I agree 100% .... would have done Gott's Mod as there is little likely hood I would have spent the then near $300 (there is one at
Amazon for $200 Amazon for $200
) the PO spent on that TruFlow setup back in 2008 (receipt in glove box), but because it does NOT use underhood air like you say, I like it's looks.
Old 01-30-2016, 09:29 PM
Jacob-M's Avatar
Jacob-M
Jacob-M is offline
2008 F150 4.6
I have the Volant air intake with dry power core filter. It is still a boxed in filter but looks like slightly bigger tubes up to throttle body. It pulls air from the stock hole in the driver side panel while also pulling from the front behind the headlights.
Jon143
03-27-2018 09:47 AM
skeeter1971
02-11-2017 10:20 AM
gn4life
Ford Truck Parts for Sale
12-18-2015 06:57 PM
japrine
12-12-2014 03:11 PM
AlbusPlaustrum06
2004 - 2008 F150
08-12-2009 01:37 PM
Quick Reply: air intake
