Anyone else get a Ford "Literature Program" Notice?
So I get a letter from Ford for my SD... Looks like a recall notice at first BUT... It's a notice about front end shimmy.. "Literature Program 09L02" Affectionately known to us as ..The Death Wobble
"Your vehicle may experience shimmy, a severe vibration and oscillation in the steering wheel that begins after the vehicle travels over a bump or dip in the road and does not dampen out by itself. The condition may cause the cab to vibrate significantly.
Shimmy differs from the more typical, slight oscillation of the steering wheel that may occur immediately following wheel impacts and disappears on it's own. This type of steering wheel oscillation is a normal characteristic of most trucks, especially a 4x4 vehicle with a solid front axle."
HERE'S MY FAVORITE PART :
"What should you do?"
"TO PREVENT SHIMMY:"
"Maintain Recommended Tire Inflation Pressures"
Then it goes on to show you where the tire pressure label is..tells you to use only the sizes that came on it, not to make suspension modifications to the truck or modify it.
All in all,,,a bland c.y.a. drafted by the lawyers
I've had it happen one time, & it was one of the scariest experiences I've ever had in a vehicle. It didn't help that I was towing an 8000 pound generator when it happened. It literally felt like all 4 wheels lost the lug nuts & were falling off at 65 MPH. The truck didn't stop violently shaking until it came to a complete stop.
I got the same letter too.
It happened to me in my 06. It had under 20k miles on it. I was lucky to get her onto the side of the road. I was going 70mph in the hammer lane and went over a bridge overpass and wham!
It never happened again.
Years later it happened to a coworker and I in our work truck on the exact same spot. We've both been over that stretch of road thousands of times and never had an issue before or since.
Nobody believes you until it happens to them.
Ranger Louie
02-13-2008 09:33 PM
9902ford
1997-2006 Expedition & Navigator
01-07-2008 05:46 PM
