Installing factory foglights
I replaced one of the lights on my 08, and the plug is located where the frame and bumper meet. It should be easy to find if it is already there. However, mine is a 450, and they are wired to one of the Auxiliary switches in the cab, #3 actually. So they come on when I turn them on, regardless if the headlights are on, high or low beam.
on
I am doing something similar right now. I just bought an 08 350 that has the factory fog light switch but no fog lights on the truck. It appears like the connector for the lights is right there on the radiator support, driver side up top. I just bought a used buckstop winch bumper and it came with a set of lights and what appears to be a factory harness that plugs into this connector and feeds the lights. Will try it out and check back.
I found the plug by the drivers side headlight. I also have a similar plug by the passenger side headlight.
Slowmans- email me the details. mkwfarm@yahoo.com
Ok guys, I installed a headlight switch with the fog light option. When I pull the switch to activate fog lights I still do not have power at the fog light wiring harness plug. You guys with factory fog lights, do you use the headlight switch or are your fog lights controlled with an auxiliary switch?
Everybody knows the key does not have to be on for...wait, HOLY S&%T that worked!!! I can't believe it was that simple. Key on, fog lights on. Thanks 73fan I don't know how many hours you just saved me. Unbelievable.
sprtsmn
1999 to 2016 Super Duty
19
10-22-2005 08:18 PM
