2011 F350 6.7 blown engine?
  #46
Old 02-04-2016, 02:58 PM
troverman's Avatar
troverman
troverman is offline
Thanks for the explanation.
  #47
Old 02-04-2016, 03:32 PM
Garyl53's Avatar
Garyl53
Garyl53 is offline
I have a build date of Feb 2011. The rear axle has a wrap-around label that says "Job 1". How do I know if I have the version of 6.7L PSD engine with the potential valve issue?
VIN = 1FT7W2BT4BEB53194
Thanks
  #48
Old 02-04-2016, 03:45 PM
capt caper's Avatar
capt caper
capt caper is offline
I had my 2011 built in September of 2010. I got 125k before trading. I don't use a Tuner and don't beat the **** out it. But I do work it hauling a vnose and 4k lb Lance truck camper.. Ran fine when traded.
  #49
Old 02-04-2016, 03:50 PM
frt2599's Avatar
frt2599
frt2599 is offline
Thanks
I have a build date of March 2010 so I know I'm affected. I though someone said all JOB1's had the two piece value's, but not sure.
  #50
Old 02-04-2016, 06:36 PM
EO2SeaBee's Avatar
EO2SeaBee
EO2SeaBee is offline
Originally Posted by Big-Foot
With the noted exception of stainless steel one-piece valves made for racing engines - Quite literally all valves are made as two piece units that are resistance welded (stem to head) then machined as one piece. I put together quite a lengthy post about this somewhere here but will be darned if I can find it now - it included a video of how valves are welded together.
The early 2011 trucks had some valves that were apparently not heat treated and QC'd properly by Ford's vendor at the time. Not all Job-1 trucks were impacted. As far as I am aware, they have no way of telling which cylinder-heads / engines got those valves..
Maybe you'll have better luck with the search engine here than I did..
Here is the thread Randy:
https://www.ford-trucks.com/forums/1...ked-block.html
It was very educational for me, so it stuck with me when I watched the video.
  #51
Old 02-04-2016, 07:14 PM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
Thanks Doug - yup that's the one...
I went to fire off a REP for you but I am apparently shooting blanks!
  #52
Old 02-04-2016, 07:23 PM
EO2SeaBee's Avatar
EO2SeaBee
No problem Randy! I appreciate it anyway. I enjoyed the video.
  #53
Old 02-04-2016, 09:57 PM
FishOnOne's Avatar
FishOnOne
FishOnOne is online now
Received 1,437 Likes on 887 Posts
Gotcha covered.... Reps sent
  #54
Old 02-04-2016, 11:09 PM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
Thanks Troy!
  #55
Old 02-08-2016, 12:52 PM
golfgooroo's Avatar
golfgooroo
golfgooroo is offline
Great info on valve manufacturing! BUT at what point does a known manufacturing defect become a recall? If the Job1 trucks have valves that esentially have defects, what enables Ford to do nothing about it?
  #56
Old 02-08-2016, 12:55 PM
BCM's Avatar
BCM
BCM is offline
Great post. I'd like to know the same thing. My 2011 is also Job 1.
  #57
Old 02-08-2016, 03:19 PM
frt2599's Avatar
frt2599
frt2599 is offline
Probably because the failure rate is so low, but that doesn't help the people who's engines blow up and have a 15K repair bill.
  #58
Old 02-08-2016, 06:59 PM
dlibson's Avatar
dlibson
dlibson is offline
It's not a safety issue, and it's not causing injury. It won't ever be a recall. Recalls are NHTSA ordered 99% of the time. Manufacturers don't do recalls unless they are told to. You get a warranty, if you truck fails during it, you are covered. If it's after, well that sucks. But that's how it goes.
  #59
Old 02-08-2016, 08:20 PM
17 Oaks's Avatar
17 Oaks
17 Oaks is offline
Originally Posted by troverman
I found a new long block Z06 engine for $13k:
Chevrolet Performance LS7 7.0L Crate Engines 19244098 - Free Shipping on Orders Over $99 at Summit Racing
It's also an easier install than a Ford 6.7L.
Thanks for the news.
That is not a bad price from Summit for that long block, its the old Z06 (LS7), but get this, the NEW Z06 (LT4) cranking out 650hp/650 Torque is $15.6 MSRP for the long block.
I was doing a built few years ago and the LS7, was over $20 large even with my shop discount, I had to take a pass on it. I got an e mail fromm Chev Perf saying they had dropped prices BIG TIME, but I blew it off. I just went looked and my jaw dropped...Crate Engines: Classic Chevy Race Engines | Chevrolet
Looks like the BowTie boys have got SERIOUS for selling the good stuff.
  #60
Old 02-10-2016, 04:29 PM
golfgooroo's Avatar
golfgooroo
Crystal, please help me to understand how Ford is dealing with this issue as a whole. I would like to understand how common the problem is. Having factual numbers helps to understand what folks with Job1 trucks should do. Everyone's risk tolerance is WAY different, and I don't want to rely on the number of failure posts to judge how wide-spread the issue is. Much appreciated if you can shed some light!
Quick Reply: 2011 F350 6.7 blown engine?
