54 F100 Wiper Delay?
You can get a universal wiper delay switch, $50-$60, or you can get the switch and relay from an older Ford truck, price varies.
I don't have part numbers for either one, but they are usually available on eBay.
The one I show from the older Ford truck is for a '73-'79 F-series or Bronco. If you go with that one you will need a 2-speed motor.
This company sells a switch with the delay built in:
Delay Switches for 2 Speed Motor : AM Equipment
No it isn't.
No it isn't.
The matching switch is E7TZ-17A553-A / Marked: E7TB-17A553-CA
Intermittent wipers introduced in 1973 F100/350 & 1978 Bronco.
The 1973/79 intermittent wiper switch has the same applications + 1971 Torino: D1OZ-17A553-A / Marked: D1OB-17A553-AA
1973/79: There are two different wiper governors: D3TZ-17C476-A (1973/77) / D8TZ-17C476-A (1978/79).
Bill, that's what I get for trusting an eBay listing. I should know better.
Thanks for the good numbers.
I like the one Ross referenced: AM Equipment : Delay switch, for one motor, 12V [311-1006] - $63.54
It does what you need, looks like it will fit in the original location, and the original **** can probably be modified to fit.
OKC54f100
03-21-2013 02:07 PM
krautwolf
07-20-2005 09:01 PM
53choptop
11-15-2003 08:45 PM
