1999 6.8L v-10 coolant loss
Old 01-22-2016, 10:55 AM
clem32's Avatar
clem32
clem32 is offline
Helping a friend out here with a 1999 F-450 V-10 Rebuild. Replaced Heads w/Refurbished, Felpro head gaskets, and Torqued Heads To Specs! Motor started right up and ran very smooth. Then after a few hours started using antifreeze. Steam in Exhaust and can smell it also. Some bubbling in degasser tank. Engine Temperature staying normal. My guess is one of two possibilities ....Head Gaskets again....but this is hard to believe after taking much care in following Ford's procedures. Is it possible for the antifreeze to move through this intake into the cylinders due to Crack or Bad Intake Gasket? Plan to do a pressure test and Compression test. but thought id question someone more familiar with this motor then I. Thanks for your input if you've had any experience into this problem.
Old 01-22-2016, 03:48 PM
clem32's Avatar
clem32
clem32 is offline
I reposted this under Super Duty an Heavy Duty.....thought that might be better suited.
andrewzx92000
06-13-2018 04:02 PM
lance65
Modular V10 (6.8l)
13
04-27-2018 12:59 PM
clem32
1999 to 2016 Super Duty
02-05-2016 02:04 PM
readyakira
05-29-2012 08:46 AM
Roger Samford
08-30-2011 03:12 PM
Quick Reply: 1999 6.8L v-10 coolant loss
