09 3.0 alternator overcharging
Hi, my 2009 Escape, 3.0, had a random battery light on last night. I checked this morning and the light is out, no codes, and the running battery voltage is 15.8 and up to 16.8 volts.
Does the alternator have a voltage regulator? Or is the voltage controlled by the PCM?
Any thing to check, besides clean and tight connections?
Thanks Artie
Thanks Artie
What's the temperature in Indiana? I think that's where your profile says you're at. 14.5 to 15 volts after starting in subzero temps would be what you want to see.
Your numbers are way too high. Back up a second. What are you using for measurement? Just about any powered DVM will become wildly inaccurate with a weak internal battery. Just Sayin'.
But, since you just had a battery light, better get it checked out and sure sounds like bad regulator, loose connections, etc. Still, pull the battery first and charge it up and test, alternator sounds like it's going south though.
As you know the problem is a bad battery can damage a charging system and a defective alternator can ruin the battery. Breaking the cycle of abuse is the idea.
If you look at online parts pics of the alt, you can see a three-pin connector sticking out the side near the rear of the alt. That should be the regulator.
Whether the internal regulator can be replaced like many Ford alts from the outside, I don't know. A quick check of Rockauto.com and O'Reilly did not turn up a voltage regulator as a replacement part.
Diverdan0430
06-19-2017 02:30 PM
hoxiii
12-03-2006 05:56 PM
garymc
1983 - 2012 Ranger & B-Series
02-20-2003 11:23 AM
