Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 10-30-2003, 11:23 AM
barneybadase is starting off with a positive reputation.
Thanks, I'll try it
  #32 (permalink)
Old 11-06-2003, 09:16 PM
Majisto is starting off with a positive reputation.
Man, my Vulcan is a newbie here. It only has 64K miles on it. AX4S trans-axle is a bit jerky into gear, but oh well. Vulcans don't die, and that's the truth.
__________________
2000 Explorer XLT SOHC V-6
2000 Taurus SE V-6 "Vulcan"
  #33 (permalink)
Old 11-07-2003, 10:43 PM
BVFD1983's Avatar
BVFD1983 is starting off with a positive reputation.
1998, 62,000
  #34 (permalink)
Old 11-25-2003, 03:46 PM
hifiwasabi is starting off with a positive reputation.
On my 1993 Aerostar, there was 165, 000 on the *ORIGINAL* engine, then I started driving it and spun a rod bearing on #6...oops. My old man gave me hell for it too but then I found him a new one with 152, 000 on it...runs better than anything else on or in the van.
__________________
FINALLY, a ranger to play with...
  #35 (permalink)
Old 11-26-2003, 04:22 PM
Jason175 is starting off with a positive reputation.
'94 3.0 192,000 miles! Just getting started!
  #36 (permalink)
Old 12-13-2003, 05:19 AM
vintene is starting off with a positive reputation.
170 k on 93 4x4 ranger 3.0 and still same clucth and running strong
  #37 (permalink)
  #38 (permalink)
Old 12-16-2003, 09:30 PM
BF_JC230 is starting off with a positive reputation.
Miles on 3.0
My engine had 230,000 miles on it before I was given in out of a 1988 aerostar, before I started my (2nd) replacement project it clocked about 275,000 and would still break my 235/45/r17s. But the rear main is starting to drop oil, and I want to play with the power plant, so I bought a new OEM engine, but for normal use a new rear main seal is all my engine would have needed. -Jake
__________________
In the drive way...
1968 Mustang GT
1989 Mustang GT
1994 Mustang GT
1980 Mercedes with a Ford 3.0 S/C
1990 VW VR6 Corrado
2004 Focust SVT
2002 Focus ZTS
  #39 (permalink)
Old 12-20-2003, 08:26 PM
Diesel_Dummy _ is starting off with a positive reputation.
i got about 80 miles on my 04 already
__________________
2002 Explorer 4x4 XLS
1990 F150 4x4 XLT
2004 Ranger Edge 4x2
Mi state and ASE certified master mechanic #M236922
  #40 (permalink)
Old 01-01-2004, 02:53 AM
3LiterBeater's Avatar
3LiterBeater is starting off with a positive reputation.
My dad took his 93 3.0 to ~240k miles, and that was stop and go L.A. traffic too. He gave it to my cousin in 98 who drove it beyond ~340K and then sold it... Replaced the clutch in it once, and changed the oil... Also had an 86' 2.9 that went well past ~350K miles... Had a Probe GT that made it to ~140K and dropped the transmission, ran to ~215K and dropped another tranny... Finally died at ~279K when a Powerstrokin' F350 decided to take it's lane...
  #41 (permalink)
Old 01-08-2004, 11:24 AM
bandit6 is starting off with a positive reputation.
I've got 241,000 miles on my '91 Ranger. I bought it new in '91 with 39 miles on it. Never touched the motor, but I have replaced the clutch 1 time. Overall, I've spent less than $1200 on repairs, that weren't just normal wear items. I trust it more than the other 2 newer trucks that I have. If you change fluids and filters regularly, there's no telling how long it'll last!
  #42 (permalink)
Old 01-08-2004, 09:22 PM
ArizonaDPS is starting off with a positive reputation.
77,000 on my '98 3.0L. Just got a blown intake manifold gasket, bad water pump , bad rear axle seals and the accumulator for the a/c is rusted out.
And that on a truck that is maintained to the letter of the owner's manual. Replacing most items before they are due, driving with a light foot, maximum of 4000 miles between oil changes, 3rd pcv valve, never towed or hauled anything and I've worked graveyards for the last 5 years...meaning she never sees the heat of the day or stop/go traffic.
__________________
1998 Ford Ranger 4X2 Ext Cab XLT 3.0
1966 Lincoln Continental convertible
  #43 (permalink)
Old 01-12-2004, 07:32 PM
Saurian's Avatar
Saurian has a good reputation on FTE.Saurian has a good reputation on FTE.
I have a 3.0 in my Taurus and it has set a very high level for reliability for me. Only problems I have had was it used to RARELY start bucking and die in summer heat...but wait 5 or 10 minutes and it would go off just fine. Second is currently what has occured - the car won't idle now. It will start and I can hold my foot on the gas and keep it running, but at 0 throttle it won't idle, it just hiccups and dies. Otherwise..150K or so and it was good up till then. Transmission on the other hand...::mutters::
  #44 (permalink)
Old 01-13-2004, 07:09 AM
Saurian,
You might have the Idle Air Control Valve cleaned or replaced. My '97 F-150 did the exact same thing. I bought some throttle body cleaner at the parts store, and cleaned it myself Problem fixed!
  #45 (permalink)
Old 01-15-2004, 10:19 AM
dreysgroove is starting off with a positive reputation.
Miles
125 K on a 94 Ranger 3.0. Engine runs fine, transmission is starting to go because the fluid was NEVER changed until about 100K. Getting ready to tow a trailer from Nashville to San Francisco, wish me luck!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
