Gurgling on start up??
Didn't think anything of it but i have noticed a few times this week when i start the truck after it's to temp, shut down for an hour, the restart i hear coolant gurgling iin the dash area??? Was very noticeable this evening. Still no overheating and heat blows nice and hot. Still getting the blows warm to a certain temp, then cold to a certain temp, then hot once to temp then will stay hot until fully cold soaked. Think my tstat is not acting right?
I'd put a pressure gauge on the cooling system and see what it's running at.
I know my truck was gurgling quite a bit after starting and after shutting it off it would do it.
It turned out to be head gaskets leaking, after I put a gauge on it went up to 18 psi at a idle.
Hope it's not the same thing going on with your truck. But putting a gauge on it will tell you for sure.
I've been thinking an air leak for over a year. Level is staying consistent (checking at cold soak) can't think of how to find the air leak.
86stepsideF150
03-11-2008 08:31 PM
