triton has been sitting 3 years. tips? - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Log In
Old 01-20-2016, 08:24 PM
mappy881's Avatar
mappy881 mappy881 is offline
mappy881 is starting off with a positive reputation.
Hello i might be getting an E250 it has a V8 triton i am not sure if its a 5.4 or 4.6, but i do know it has been sitting for about 3 1/2 years and its gonna either be free or very cheap so i would like to get it running since there was nothing wrong with it when it was parked!
What i would like to know is will the spark plugs be even harder to remove since its been sitting? and if so what should i do before i take them out... soak them in penetrating oil? I really don't wanna break them since its an Econoline, and Econolines are a pain to just remove spark plugs! I don't even wanna try an remove broken ones!
any tips are welcome!!
Old 01-21-2016, 07:26 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
first thing i would do is drain the gas tank, and flush the fuel lines and fuel rail to get as much of the bad gas out as possible. then put 10 gallons of fresh gas in the tank and try to get it running.
it will run like crap until you get all the bad gas out of the system and get the injectors cleaned.
once it is running ok then i would change the oil and filter,trans fluid and filter, plus the fuel filter.
__________________
Tom
Moderator of the "not wrapped too tight forum"
rarely in life do you meet a person that will drop everything to help a stranger,
and give the shirt off his back to a friend.
Steve Price was that kind of person.
Godspeed "window licker", the short bus will never be the same with you gone.
Old 01-21-2016, 05:03 PM
rsylvstr rsylvstr is online now
rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.
Robert Sylvester, CEHT
agree...except I would go for five gallons.
__________________
Master Chief, HMCM(FMF/AW)
JOIN US http://nyfirearms.com/forums/index.php?referrerid=1780
The best battlefield medicine is fire superiority
2001 SCrew Lariat 4x4 5.4L 4R70W 3.55 's LS
Conti eco tires, K&N Series 77 CAI
Old 01-21-2016, 08:35 PM
davester250 davester250 is offline
davester250 is starting off with a positive reputation.
I bid 2 gallons!
__________________
2008 F250 Supercab, 8' box, 4x4, 5.4L3V
Old 01-21-2016, 10:15 PM
mappy881's Avatar
Thanks for the info !
Old 01-22-2016, 09:28 AM
JWA's Avatar
JWA JWA is online now
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
My WAG would be plug removal shouldn't be any more difficult after so much sitting time. At any rate follow replacing the gasoline first before getting it running first.
Speaking of that depending on the climate where its been sitting should any sort of pre-starting steps be followed----like turning the crank by hand first?
Old 01-22-2016, 10:27 AM
i ain't rite
my 2000 sat for 8 years when i got it running. the fuel was so bad it actually turned to varnish. it took close to 2 months to get the crap out of the system enough where it would actually accelerate when stepping on the throttle enough so it could be safely driven on the road.
__________________
Tom
Old 01-22-2016, 11:24 PM
mappy881's Avatar
its been sitting in gainesville FL so its pretty humid
Old 01-26-2016, 10:25 PM
firebirdparts's Avatar
firebirdparts firebirdparts is offline
firebirdparts is starting off with a positive reputation.
You need to just ignore the spark plugs for now. You can replace them after you get it running. get it nice and hot a couple times. if it really needs a set, then yes, penetrating oil is a great idea.
Old 01-27-2016, 07:05 AM
i ain't rite
agreed. sitting will not hurt the plugs, it is the bad gas in the system that turns to varnish that screws everything up.
__________________
Tom
Old 01-28-2016, 12:40 PM
Diamnd1's Avatar
Diamnd1 Diamnd1 is offline
Diamnd1 is starting off with a positive reputation.
Quote:
Got my vote
__________________
2004 F250 CCLB Lariat FX4(Lurch)
CAI, Y-pipe, 5 Star tuned
2004 Nissan Altima(Squeeky)
2016 VW Beetle(Turbo)
Old 01-31-2016, 01:19 PM
mappy881's Avatar
Thanks for all the replys! once i get it, and IF i get it running im not sure what to do with it! maybe make it a dually van?!
Old 01-31-2016, 03:02 PM
i ain't rite
or a demo derby rig with lots of cameras filming every angle of the action!!!
__________________
Tom
Similar Threads
08 F150 5.4 Triton engine swap. MarloLemieux Engine Swaps 6 01-31-2016 09:13 PM
Puking Up Spark Plugs. Spark Plug Blowouts. _Rick_ Super Duty & Heavy Duty 55 07-19-2015 11:28 AM
Spark Plug Changing Tips - 2000 E350 deeplist 1968-2013 Full Size Vans 4 10-25-2014 08:31 AM
Need advice on spark plug removal '99 V6 d.weglarz13 1997 - 2003 F150 2 10-01-2014 12:07 AM
5.4 Triton issues multi issues. f350hammer General Automotive Discussion 7 07-22-2014 06:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
