bolt torque specs
bolt torque specs
Does anyone have the torque specs for the Damper, flex plate, torque converter and timing cover.
Im swapping over everything from my dead V10 to a rebuilt long block and I can't find the torque specs anywhere. I found the oil pan bolt pattern and specs but that's about it.
2004 Ford v10 6.8L Automatic. Bucket truck.
crankshaft pulley
torque to 66ft/lb
loosen 360 degrees
tighten to 37ft/lb
tighten an additional 90 degrees
Timing Cover
Tighten fasteners 1-15 to 18ft/lb
Tighten fasteners 6-7 to 35ft/lb
Flexplate
Install bolts in sequence shown
Tighten to 59ft/lb
Torque Converter to flexplate nut
26ft/lb
torque to 66ft/lb
loosen 360 degrees
tighten to 37ft/lb
Timing Cover
Flexplate
Tighten to 59ft/lb
26ft/lb
wayneasbell
08-02-2007 02:24 PM
