information on the 5,4
I have owned Ford trucks for a long time now I have had v-10's. Its time for another truck,there is a 09 truck I'm looking at but it has a 5.4 I do a lot of towing stock trailer and a 34 foot camper. It being a three valve I know about the spark plugs breaking when you go to take them out. I just am leery of problems and I won't be happy the way it pulls. I love my V-10's they work so good will I be happy with the 5.4
Thanks
Thanks
Thanks
Thanks
If you tow that often and tend to tip the scales a bit on the heavy side....maybe consider getting f250 or f350....heavier transmissions suspensions & way better tow and cargo rating.
If your still curious ....ask if you can hook up to your camper and take test drive with it. This way you'll have a much better Idea of how well it will work
No matter, If the principle chore of this truck is towing. I'd still ask to hook up a trailer to it and see how it performs>>>for you. Are you trying to steer clear of diesel engine? the diesels would bring a pretty good economy to the table not to mention better low end grunt.
I have over 400,000 on my 5.4 and towed a loaded 3 axle 5th wheel toy hauler up a long, steep hill in 'passing gear' just fine, meaning no pinging or overheating while accelerating. Great fuel mileage 2nd to the 6.7 i would say. If your worried about the plugs you could buy the fix it kit from the parts store and put the new inserts in. If I was personally worried about the plugs I would remove them all with the engine cold then replace them with Motorcraft single platinums with a little anti seize on the threads, torque them to specs. Just be careful about cross threading. I think that's what a lot of guys are doing. If you do suspected one was cross threaded while removing, just use the thread insert and you won't have to worry about it. It's not that hard to do since it uses the spark plug tube to center itself. The kit comes with everything to do 1 cylinder. You can use the drill bit and tap over, you just need another insert. I think they might be forged steel?
Overall I'm sure you'll be happy. The issue I see is when you're pulling your 34' camper. The uphill climbs or a strong headwind will be much more of a strain with the V8 vs. the V10. On the plus side, when you're just doing your normal driving around you should save on the fuel bill.
I had the 5.4 in my super crew F-150 4X4 and it pulled my 24' travel trailer just fine but struggled on long steep grades. We had an F-250 4X4 with the 5.4L at work and it was a gutless wonder. If it were me I would stick with the V-10 in your situation.
