I have a 2001 7.3 diesel F250 that is totaled with most of the body and parts being fine except the frame
I was wondering what options there are as far as an engine swap with the 7.3 and another truck, hopefully newer
Thanks for any help
A running donor is more than half the battle. You should be able to find a nice truck with a blowed up 6.0 if what I read here is correct. I would predict this will be a 8.5 on a scale of 10 as far as engine swaps. Get your tools out....
Where are you located? Insurance companies and diesel shops is where I'd check. I know of a few guys down in south Texas that had relativley new trucks totaled by water in the fuel. If you don't know any adjusters, you may be able to get a local body shop to give up some names.
Best of luck, I'm looking for a totaled 7.3 to put into an Excursion or a V-10 and have had a hard time finding anything cheap.
