Wheel / Tire Mock Up
Old 01-19-2016, 12:32 PM
eman92082's Avatar
eman92082
eman92082 is offline
This tool design has been around for a while but I thought I'd pass along what I did for those folks who may not be familiar with it.
The outer "wings" represent the intended tire radius at the top. I can swap them out with others for different radius sizes. I impression stamp the size on them.
The 3/8-16 threaded rods are cut to represent the intended section-width of wheel/tire combos. Additionally, I cut lengths that can be adjusted in / out until interference occurs to verify the "real-world" cavity I have to work with.
On the work-bench, I pre-adjust various back-spacing's. After it's set up, I install and spin while observing the clearance results.
I'll be running Tru-Spoke Steelies. They have a standard back-spacing but for an extra 15 bones, they'll back-space to suit. I found I can run their standard spacing in front but will have to specify the dimension on the rear.
I hope this is useful to someone
Dawg-A-Saurus.
BleednBlue68
1999 to 2016 Super Duty
12-12-2013 08:08 PM
emmagator
11-19-2007 09:54 PM
Quick Reply: Wheel / Tire Mock Up
