how would u guys fix this
That can be patched. Cut out the rusted section in a semi oval arc and cut out a matching patch out of metal of the same thickness and bend to shape. Be careful not to cut too deep. The reason I would make an 'arch' cut is because I find it neater to weld when there isn't corners. I would spot weld a nail to the patch to hold it place if you can't acccess from behind. Spot weld the patch in place and grind off the nail. This is probably the way I would do it but others I'm sure will be along with their methods.
Here is the "correct" way...Metal Finishing and Rust Repair
Now that you know the right way, you may find that your pockets are not quite that deep, somewhere in the neighborhood of $6K, so it will be up to you to choose what works best for your truck and your wallet. When I do these repairs I cut out any portion of the roof skin that has rot and weld in new metal. The inner channel, the part you can see through the hole, is usually also rusted. I have found that this rust can be treated by wire brushing and blowing out channel to remove all loose material. I use Rust Seal, a rust encapsulating paint, to thoroughly coat this channel and the underside of the roof skin in this area. To show you how poorly the seams are sealed from the factory, take a look at this photo...this is my cab that I sealed the inside channel on. The black seeping through the seam is the Rust Seal. This is the reason these cabs rust in the roof seams, they are not weather tight.
You probably would find more of that if you started looking. Know that it is rusting from the inside. It's from condensation on the inside of the roof skin running down to the metal that makes up the front window frame. Whichever way that you intend to repair it, spend some time applying effective corrosion-proofing as much as you can on the other side.
Received 4,132 Likes
on
Thanks again for the help
johnboggs21
05-27-2012 10:19 AM
xcrunner2616
17
04-06-2011 06:33 AM
Alcaeus
19
11-11-2009 07:03 AM
19fifty4
15
10-02-2008 02:07 PM
codys50ford
10-01-2007 10:40 AM
