RE: 1956 F100 with 72 Torino frame, Tranny
Hi Guys and Gals,
Newbie, I'm interested in purchasing this 1956 Ford F100, Looks nice and solid, with rebuilt 350 windsor,( rebuilt 72 Torino tranny, 72 Torino Rear end, 72 FRAME), redone interior, nice stands, fresh paint. He said during painting he sand it down on the body, but not to sheet metal.
My question for you guys, is a 72 Torino Frame, Tranny, and Rear commonly used for the F100? What the is the Plus why they use this set up? What the negative on this set up? If you I do purchase it, my plans are to Pro-touring it, with Coil over front and rear suspension, Mustang II front, Disc brakes all around, 9 in Rear 3.73 and later down the line for EFI crate motor and C6 Tranny overdrive. Can I put this set up on this existing 72 Torino frame? Or will have to look for an original F100 frame? How about the value of it with 72 Torino frame, will it be less desirable? value? Also are most 56 going to have rusts, no matter what without restoration? Your help and opinion will help me make a better decision, Thanks in Advance
72-79 Torino/LTD II was a full frame car, but it is not a truck frame. No way would I touch this mess with a 10 foot pole. If you want a truck to do the mods you listed, look for a better example that hasn't been hacked and pieced together by some moron. Car frames are flexy and floppy and have no real structure. They are a mount for suspension, not a strength center. They are not suitable for building a truck project on.
That was a popular swap years back. The frame is cut off just forward of the firewall and the donor frame is welded in. There are lots of these around. My truck has a 70 LTD front clip, motor/trans and a 72 Torino rear. It was that way when I got it. There are some done with other frames like Volare.
I have no issues with my truck but I would inspect it closely before you buy it.
The pics look good... Welcome to FTE!
Hi Guys and Gals,
ALBUQ, I didn't get a chance to see it in person yet, he's 4 hrs away from me, so before I head out, I wanted to see if it worth wild.
Avf100, if it just the front clip of the Torino, that will work for me, this way I'll just switch to Mustang II clip, as long as the rest is F100 frame, I wouldn't want the frame to be welding on to the body, sound a little too Frankenstein for me, beside I want to take it off for future restoration.
GMbusa, he out of town till next week, I did ask him for some undercarriage pictures, he can't do it until then, but he said the frame 150ft end, not sure exactly what he meant.
CharlieLed, will I'm looking to work on the project little by little, maybe I'll be satisfied before I do a full pro-tour application, This way I'll be able to use it as I go, A complete pro chassis frame project, is quite $$$$ then you got dump all the $$$$ to get your first drive, asking price $33K
My other question for you guys, since I've been searching for this 56 F100, spoke too a hand full of deals out there. Seem like a lot of these trucks are rusted out, replace repo parts or used parts, either the Cab, Bed, Floor panel, Sheet metal patches, Drivetrain and etc, are switch from original truck, Is there a Real surviver in one piece? Or it is something you have to except if you want one? What would be the Best Drivetrain and Suspension upgrades? What the best way to go, look for a full build used one or a Solid starter and work from there as you go?
I want to Thank all you guys for the warm welcome, and helpful info
