1987 f150
Old 01-18-2016, 11:05 AM
HarleyLover's Avatar
HarleyLover
HarleyLover is offline
1987 f150
I have a 1987 f150 with a efi 4.9 300 and was wondering if I could swap it out for a carbed 300 or preferably a carbed 351
Old 01-18-2016, 04:38 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
Received 1,358 Likes on 1,073 Posts
Yes but why? IMO the EFI I6 runs a lot better than the carburated ones.
Old 01-19-2016, 02:15 PM
HarleyLover
cracked block and warped head plus always liked carbs more
Old 01-19-2016, 03:53 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
I'd just swap an EFI 300 back in. They have around 40HP more, and 42 lb-ft more than the carb 300.
Old 01-19-2016, 04:55 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
You could swap in a carbed 300 fairly easily. The hard part is getting everything to work afterwards. The ignition would need to be changed to the older Duraspark 2. Then you could remove the frame rail mounted high pressure pump and run off the in-tank low pressure pump(s). The next part is triggering and then latching on the fuel pump relay with no computer.
If you have an E4OD, perhaps not in 1987, then you have to figure out how to make the computer controlled transmission to work.
A lot of work to go back to the stone age.
Old 03-01-2016, 06:00 PM
HarleyLover
got the motor in the 87 now i need to know what to hook up any advice helps im 19 and this is my first motor swap
Old 03-01-2016, 06:06 PM
Lead Head's Avatar
Lead Head
What motor?
Old 03-01-2016, 06:09 PM
HarleyLover
couldnt i just use a three way fuel pressure regulator and have an inlet a return line and and outlet to the carb
HarleyLover
inline 6 300
Old 03-01-2016, 11:02 PM
My4Fordtrucks
Swap over the parts from the other I6. Intake and exhaust manifolds, injectors and accessories. The wire harness is still in the engine bay so plug things back in. I still think you are making this harder on yourself and going backwards if you are still trying to change to a carburater.
Yes, you will need to get the 45-50 psi down to 5-6(?) psi for the carb.
Old 03-02-2016, 10:22 AM
HarleyLover
the block is cracked does anyone know what wires i need to hook up to get it just to get in running
Old 03-02-2016, 10:41 AM
rla2005's Avatar
rla2005
rla2005 is offline
As previously noted the in-tank pump(s) are low pressure, remove the inline high pressure pump and keep the fuel reservoir. The carb will work fine with the pressure provided by the in-tank pump. No need for a pressure regulator.
What do you plan to use for the ignition?
Old 03-02-2016, 03:57 PM
My4Fordtrucks
The block you swapped in is also cracked? You stated in post #11 that you already swapped out the engine with the cracked block. What I was saying is all you needed was the long block and swap over the parts from your old engine.
Old 03-03-2016, 07:16 PM
HarleyLover
sorry im getting jumbled the old motor had a cracked head and block so i put in the carbed motor which ran when pulled before the swap the motor is now mounted up to the trans i need to know what wires to hook up to get it to run
Old 03-03-2016, 07:18 PM
HarleyLover
rla2005 the ignition is stock if i can use it i will but if not what would be a cheap but good system
Quick Reply: 1987 f150
