1976 f150 with a 360 starting issues
so i bought this truck just before thanksgiving. it wasn't running, it needed a radiator and carb to get running. so after acquiring those parts, and many others, i am at a point i could use some help with.
the carb needs a rebuild so out of frustration i dumped some gas down the carb and cranked it to see if it would run. it wanted to. while i was cranking it, it acted like it would run, but as soon as i let off the key it would die immediately. this leads me to believe i am loosing power to the ignition somewhere. am i heading in the right direction?
i know it could be many other things, so what would you guys suggest?
coryv4
04-25-2014 04:10 PM
usmctribe
05-29-2012 12:57 AM
