info on GT40 heads plse - Ford Truck Enthusiasts Forums
Old 08-08-2003, 11:35 PM
ferguson777's Avatar
ferguson777 ferguson777 is offline
ferguson777 is gaining momentum as a positive member of FTE.
I would apreciate an education on GT40 heads- I've everything I could find in here and what little I could find in my books and I'm still left with many questions -
i.e. - how many different variations are there?
(like GT40s, GT40Ps, any others?)
- what are the differences or pro and cons of the different
variations?
- What engines (year, displacement and model of vehicles) did they come on?
- If they came on both 5.0L and 5.8L engines, are they the identical same head or were there differences?
- What sort of torque gains can one expect on a very mild 5.0 or 5.8? (i.e. with SDI, headers, MSD6, MILD cam, mild porting)
Thanks,
Old 08-09-2003, 04:17 PM
jwtaylor jwtaylor is offline
jwtaylor is starting off with a positive reputation.
Don't hold me to this but I believe they came on some 90+mustangs gt or cobra I am not sure. They definitely came on the first gen lightning, and a few crate motors. From what I have read they are a very good up grade from other stock heads. Gt40P heads came on explorers I think they are pretty close performance wise to the gt40 just have a little better combustion chamber. The only drawback to the p's are they require a different header than what the 302 and 351 would usually use then again some have used them and fit regular headers I think it's probably more on a case by case basis as to weather or not the header with fit your application. Hope this helps some
Old 08-09-2003, 04:36 PM
Hit Man X Hit Man X is offline
Hit Man X is starting off with a positive reputation.
Here are some flow numbers and such for all the SBF heads:
Here is what I cam up with...many of these are not in the 160cc area some are closer to 185cc but I got as close as I could.
.500 LIFT - 28" of H20
156/108 - Stock E7
185/129 - GT-40
196/139 - GT-40 P
204/144 - GT-40X
208/175 - GT-40 PORTED
210/156 - GT-40Y
205/141 - Dart SR
219/151 - "Thumper E7"
237/172 - Brodix 5.0
237/203 - GT-40 PORTED (1.94/1.54 valves)
243/185 - AFR165
246/194 - GT-40Y PORTED
245-251/170 - Edelbrock (intake flow based on valve sizing)
251/187 - Trick Flow Twisted Wedge
267/185 - AFR185
I could not find any data from Canfield, World Products, of the GT-40Y heads... for heads in this size range...must be a secret or something. But their heads are all almost 180cc+ heads which barely fit in this ~160cc range.
GT-40 irons have 1.84/1.54 valves
GT-40P irons have 1.84/1.48 valves
GT-40X are aluminum heads with 1.94/1.54 valves
GT-40 irons came on 93-95 Mustang Cobras and up to 1997 5.0 Explorer (I think 1997). The P came out after the true irons left the market around 1997. The X head is a FMS part. The iron heads only came on 5.0 motors (and the 93-95 Lightnings)...to use on 351W you will need to drill out the bolt holes to 1/2".
All of the GT-40 variety wake up to port work (well any head). Clean up the valve throats, open up the exhaust port, open up the intake port, clean up the short radius from the intake to the valve, deburr the combustion chamber, and a 3 angle valve job is great. I would not port match the intake and exhaust to their respective Fel-Pro gaskets, you could slow down velocity and lose power. Stock valve sizing is best to stay with per head inorder to keep up velocity.
Any of these heads will easily give you 20-30hp over the stock E7 and 30-40hp depending on amount of port work involved.
THAT SHOULD MAKE YOUR HEAD SPIN!
Old 08-09-2003, 06:43 PM
BroncoDave's Avatar
BroncoDave BroncoDave is offline
BroncoDave is starting off with a positive reputation.
Here's a link
http://www.themustang-net.com/tech_articles/gt40p.shtml
to a good tech article comparing the GT-40's to GT-40P's. Personally, for what I do with my Bronco I felt the "P" was the best choice. I recently purchased a set in excellent condition from a guy on ebay who seemed to have a limitless supply. I won't have the money to tear the engine down 'til next spring because my E4OD is junk and needs to be replaced. So I can't tell you whether it woke up my 351 or not...
Old 08-09-2003, 11:40 PM
Guys,
Thank you all for the info and the link. I've printed it off and will digest for a few days. I may have a few more questions, but the quantity and quality of info is excellant, possibly more than I expected.
Thanks again!
Old 08-11-2003, 10:52 AM
Having read all the great info you guys posted and having read the links as well, I just have a few more questions;
-In looking for donors for the iron GT40 heads specifically Explorers what was the first year of 302 that came with them?
-Can the approx. 20% gain in flow be expected over the stock head on a 351W as well as the stock 302 head?
-The iron GT40s will take normal 351W/302 headers, correct? (I understand that the GT40Ps will usually require a special header.)
- If used on a 351W, will any 351W intake manifold fit?
Thanks,
Old 08-11-2003, 11:13 AM
offroadbronco offroadbronco is offline
offroadbronco is starting off with a positive reputation.
If I am not mistaken 95 was the first year. I know for sure 91-94 didn't, they only came with 4.0's.
Old 08-11-2003, 11:31 AM
As I recall the Explorer and 351W Lightning heads have a larger combustion chamber than the Cobra heads. I believe they were around 64-65cc and the Cobra's 60cc...this is going off memory so it may not be super accurate!
Looks like ~15% better flow on intake and ~17% on exhaust in stock GT-40 form. With slight port work (Clean up the valve throats, open up the exhaust port, open up the intake port, clean up the short radius from the intake to the valve, deburr the combustion chamber, and a 3 angle valve job) ~25% on intake and ~38% on exhuast end.
Non "P" heads take any stock header/manifold. P's can take stock headers it is just a PITA to change spark plugs.
If you use the 5.0 GT-40 heads on a 351W, you will need the head bolt holes drilled out to 1/2" from 7/16".
Old 08-11-2003, 05:59 PM
Jimbo302's Avatar
Jimbo302 Jimbo302 is offline
Jimbo302 is gaining momentum as a positive member of FTE.
The GT40 head was used on the 1993-1995 mustang Cobra 302. The 1st gen lightnings used a larger chambered GT40 head on its 351 for lower compression (there is a bolt on spacer kit available to use these with 302 head bolts). The explorer heads are GT40 "P" heads which feature slightly improved runner design and different plug angle, which make a standard header difficult to fit. Hence the "P" specific header.
Old 08-11-2003, 06:09 PM
Duh I forgot, ARP sells stepped head bolts that fill the hole for the 1/2" head bolts but have the 7/16" threads of the 302 block! Now you can use 351W heads on the 302
Old 08-12-2003, 12:13 AM
E150X E150X is offline
E150X is starting off with a positive reputation.
The first 5.0 Explorer heads (96 to maybe 97.5) were GT-40's. After then were GT-40P's. Don't know about 40's but my 40P's don't have thermacter bumps in exhaust port and don't have thermacter opennings in ends of head either. FMS mustang shorty headers outlet matches pretty close to stock Y-pipe on passenger side on truck but drivers side exits at the back of the block by the bellhousing bolt holes (and high pressure fuel lines on EFI). Good luck with your project.
Old 08-12-2003, 07:32 AM
BroncoDave's Avatar
My understanding was that any Explorer/Mountaineer w/302 from 97 on had the "P" head. Also check ebay...
In recent history 302/351W heads are the same (with the exception of a slight difference in combustion chamber volume and head bolt diameter). Any 351W manifold will fit.
As far as headers, spark plug angle is the only issue. If you can find a header that clears the plug your ok. Some people ding the primary with a ballpeen hammer, others remove their header to change a plug etc. Ford makes a stainless shorty header that clears the plug a GT40P head, but it is for the Mustang. I'm not sure about the exit angles in a truck... It is available through Summit and other places.
Old 08-12-2003, 08:17 AM
central coast mustang has a shorty header designed to use gt-40p heads in 86-95 trucks$219 doesn't state if they are coated in any way. So if you don't wanna try different headers or bang on your new ones or take them off to change plugs this is an option.
Old 08-13-2003, 12:49 AM
BroncoDave's Avatar
jwtaylor:
Do you have a link for central coast mustang? I seem to be unable to locate them on the web. I would like to see the truck headers they have for GT40Ps...
Thank you,
Old 08-13-2003, 01:37 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
my little bit- the gt-40p's were on 97.5 explorers & mountaineers till the 302 was replaced, and car craft had a good article on the gt-40s (budget iron heads put to the test- feb of 02) and just put a set on a budget ($2500) 351w- that one is on the racks as we speak
in the iron head articlethey said that the theoretical max power is 391 horse!
it also does not have any of the thermacator air passages (thank you ford!)
I also hope that they work well- I'm planning on putting a set on the 302 im building for my 61 falcon!
5.8 MAF Conversion w/GT40 Heads nighthawk285 1987 - 1996 F150 & Larger F-Series Trucks 24 01-09-2017 02:07 PM
Mild Build, Need Help! 5.0-5.8 parts interchangeability chevyassasin Performance & General Engine Building 11 04-07-2013 10:17 PM
question about GT40 heads buzzy613 1987 - 1996 F150 & Larger F-Series Trucks 10 07-24-2012 10:00 PM
ported gt40's, 351, and SD!? '89F2urd 1987 - 1996 F150 & Larger F-Series Trucks 20 11-05-2011 11:31 AM
97 5.0L heads???? f150fan1972 Explorer, Sport Trac, Mountaineer & Aviator 6 11-20-2006 01:01 PM
Tags
194, egr, gt40, heads, internal, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
