Update my mirrors...
Many folks here, myself included have gone with 1A Auto's '08+ tow mirrors, they are totally plug and play and are of very good quality. Here is a link to their new power fold version but once there you can check out the many other models they have available.
2007 Ford F250 Super Duty Truck Power Textured Black Dual Arm Power - Folding Towing Mirror with Manual Spotter Glass Pair at 1A Auto.com
Says it does not have turn signal???
- Comes as a PAIR
- Fits both LH (Driver Side) & RH (Passenger Side)
- Dual Glass
- Power Operation Main Glass
- Manual Spotter Glass
- Folding - Power operation
- Textured Black Caps
- Dual Arm Towing
- Upgrade Style
- Includes Switch, Mini Adapter Plug, Instructions, & Installation Kit
- Direct replacements
- Built to strict quality control standards
- Not Heated
- Without Turn Signal
- Without Clearance Light
Here is the mirrors that I bought.
1AMRP01095 Tow Mirrors from 1A Auto for $360 Sept/14
Ford Mirror Pair - 1AMRP01095 at 1A Auto.com
2002 Ford Excursion Power Heated Smoked Style Signal & Clearance Light Textured Black Cap & Smooth - Paint to Match Upgrade Towing Mirror Pair at 1A Auto.com
Did you take a look at these? I got them a month ago and they are great, I should have replaced mine earlier.
I couldn't find anything different other than the deeper "discount" on the less expensive ones from 1a auto that I bought. I called them once to confirm they were from the same manufacturer with the same specifications and was told they were. Always a skeptic, I waited a few hours and called back asking the same questions and got the same answers so I ordered a set. They said that I could return them for any reason, but there was no need to. The fit and finish is excellent
Fwiw, when I openly asked them about the difference in price between the two part numbers, he could not give me a reason. All of the specifications and details of the mirrors were the same between part numbers.
Good luck.
Good question and the same one that I had when I saw the less expensive ones on the 1a auto website
Good luck.
Good luck.
