Dies on freeway when rpms drop
91 5.0 5spd basically dies every time I'm going downhill on the highway, or if I am slowing down to get on the exit... Luckily it's a manual so I can just pop the clutch and it starts right back up otherwise I would be In trouble. Seems to be ok in town unless I step on it then slow down fast... Does this sound like a crank/cam sensor, or do these trucks even have one?
Sounds like the OP has a bad IAC valve.
The idle is totally controlled by the PCM Computer.
Look at the throttle linkage on the throttle body. There is a stud that the factory sets for the "base idle" When properly set a warm engine should run with the IAC disconnected. The IAC just compensates for differences in conditions that the motor faces.
That's the one I'm referring to. After my motor swap I had to adjust mine slightly to bring the idle up. It might be there to keep them from sticking closed but I'm under the impression that it is there for a base idle setting as well. The IAC is there to supplement but the throttle plates are the main source of air at idle
In my limited experience (15 years with OBS trucks) I have seen these trucks die completely when the IAC is disconnected or idle very low, i.e. 400-500 RPM. Bill has been around these a lot more than I. I would prefer to have the low RPM.....as long as the TPS closed throttle voltage is within range or the throttle sticking.
Bill,
Maybe as a factory spec they are supposed to die when IAC is disconnected. But the manual is assuming its a brand new truck with no malfunctions. In an older machine with worn parts and unknown failures whatever they may be I would prefer to have a higher base idle so the margin of error is a little larger. IE so if your IAC is sub par your not putting 100% of the engines ability to idle into the ability of the IAC to regulate airflow. Another example would be my 90 f150 with a 90 5.0HO motor in it. The 90 f150 motor and 90 mustang HO motor are vastly different animals. I'm Running the HO motor off of the stock non HO motor computer so the parameters are different so I had to adjust the base idle.
pww571
06-14-2017 06:09 AM
onafixedincome
10-13-2012 08:16 AM
meatloaf87
42
08-02-2007 01:36 PM
