97 7.3 powerstroke lack of power not fuel pressure problem
  #31
Old 01-19-2016, 06:12 PM
madpogue's Avatar
madpogue
madpogue is offline
Originally Posted by Hussler
P0069 and P0079: Don't believe these are OBS codes. P0237 could be an old code, don't know
+1; According to the various code pages here - Maintenance - 1994-1997 Power Stroke FAQ - P0069 and P0079 aren't even 7.3 SD codes. Didn't come into existence 'til the 6.DOH era. OP should probably have the truck scanned for codes again, making sure the device is set for our generation of truck.
  #32
Old 01-21-2016, 12:52 PM
Mrplow91's Avatar
Mrplow91
Mrplow91 is offline
Okay borrowed my buddies edge programer just to see what my temps and boost was at everything was normal except for the boost.... barely any psi was built i think it was at 6-7 psi WOT... but that was max redline practically. Im at a loss where do i go from here?
  #33
Old 01-21-2016, 12:54 PM
Mrplow91's Avatar
Mrplow91
Mrplow91 is offline
Even brake torqueing it didnt build above 5psi. And didnt brake the tires loose.
  #34
Old 01-21-2016, 04:26 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
I don't really want to read it all, did you check for leaks at the intake plenums, uppipes, downpipe, manifolds, etc?
  #35
Old 01-21-2016, 06:22 PM
Mrplow91's Avatar
Mrplow91
Mrplow91 is offline
Yes i have inspected it and do not see any visible leaks. But here is an update did a frequency test on the map sensor and found that it is out of range... KOEO it was at 153hz that was with no pressure applied so i am getting s new map sensor tomorrow. ICP was within range as i had already found out from my buddy who scanned the truck. Also unplugged my pcm and found no obvious sign of corrosion so threw a little dielectric grease on it and plugged it back in.
MichaelBounds
01-25-2023 07:24 PM
jmo1112
11-02-2017 02:14 PM
Archy
6.4L Power Stroke Diesel
11-04-2015 05:54 PM
edub32
25
02-20-2009 05:51 PM
Quick Reply: 97 7.3 powerstroke lack of power not fuel pressure problem
