Truck Will not crank when you turn the key
Well EGR delete went well, just took longer than I had hoped, its darn cold working outside in sub freezing temps,, I took the minimax off an 250 and returned it to stock and programmed the 350,, nope turn the key will not start did the wire trick and it turns over and fires when I put starter fluid in the intake,, but that it scratching my head now
no error codes
any ideas?
the red padlock with car inside stays on hinting its a security module issue,, when you do turn the key you hear the relay tick in the passenger foot well
I am after any inspiration now
I have cleansed all the fuel lines and have good clean fuel coming up to the fuel filter in the engine bay
Thanks for any input
no error codes
any ideas?
I just programmed the truck to take in to consideration the EGR/DPF and Cat delete and with my 250 it did the same thing until I programmed it however I have now programmed this truck and it will will not crank with the key.
I have disconnected both batteries and left it over night in case that helps? clutching at straws a bit now and I really need to get the truck up and running.
I will mess with it a bit today, sub freezing temps are limiting my time outside today
Okay some what of a success now,, I have bled the fuel system and got all air out of it up as far as the high pressure pump and return system,, still would not start, checked all fuses, last ditch attempt I thought lets see if any codes are thrown up,, HA!!! P1260 - Theft Detected - Vehicle Immobilized, now I know the direction I am going and why it would not crank and start
I will confirm as soon as i can get a locksmith out to re program the PATS system
I feel happy now
I feel happy now
I feel happy now
I feel happy now
I have had similar experience with a few 6.0Ls I worked on. Do you have a remote lock for it? If you do, remove the key and remote, close all the doors, then lock the truck from the remote. Unlock it again, using the remote, and then try again. No guarantees but it might be worth a try.
ok locksmith came out the other night and spent a good 2 plus hours,, he left me with a key he said he programmed but told me the truck had to go back to a dealer as he thought the antenna was faulty? so when the snow melts we will see what the dealer has to say,, expensive tow bill here I come
Ok moved past the theft deterrent code, had to take the truck to the dealership and have a new key programmed,, that then got rid of that code,, I then installed my MiniMax programmer and programmed the truck then for the first time it would crank over using the new key and the theft light was out and stays out except when stopped and key out the normal red pulse you should get. Sorry I never updated the posts
unleashd
36
11-15-2018 08:53 PM
