let's talk about wiper blades
Old 01-20-2016, 04:28 PM
Absolute's Avatar
Absolute
Absolute is offline
[QUOTE=Bird-Dog 250;15967054]Good point! I must have used the wrong one! It fit on there but it was a loose fit. I'll be more careful next time.
Darn metric and imperial. LOL
Old 01-25-2016, 08:56 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
Ok....
So swapped in a different spring, that didn't work...
So here's another question...
Both of my '92 F-150's came with wiper arms that have the PIN mount blade type.
I'm looking and wondering why it says '80-90 pin mount and '92-96 hook type?
Is there really any advantage to either style?
I'm going to purchase NOS wiper arms.
Old 01-26-2016, 07:59 AM
timbersteel
Well, I went out and looked at the '95, F-150 project truck and it has the hook type.
The arm itself looks stronger and wider and I believe I will just order these for both of my '92's
I included pics if anyone would like a side by side comparison.
I'm interested in opinions!
Old 01-26-2016, 08:20 AM
Ron94150's Avatar
Ron94150
Ron94150 is offline
Rain-x = no wiper blades needed.
Old 01-26-2016, 02:16 PM
cjben's Avatar
cjben
cjben is offline
^^ only at speed though...not so good around town in heavy rain..lol
Old 01-26-2016, 06:24 PM
phnguyk's Avatar
phnguyk
phnguyk is offline
I took a MR Clean Magic Eraser to mine. Love it, no more chatter, and cleans awesome.
Old 01-26-2016, 07:00 PM
ncranchero's Avatar
ncranchero
ncranchero is offline
During our recent snow I paid more attention to my chatter problem.
I told her to get out.
No, really, darn things chatter in both directions. If it's a steady rain they don't. I may try a Mr. Eraser. The blades are recent, Michelin's. Maybe Michelin blades are crappy, IDK.
Old 01-26-2016, 08:00 PM
Bruners4's Avatar
Bruners4
Bruners4 is offline
So I'm wondering what the tension is at the end of the arm where the blade assembly is attached? This would be measured with a spring scale attached where the blade is attached. Reading would be taken just as the blade started to lift from the windshield. Does the newer version of the arm require more pressure to lift the blade?
Old 01-26-2016, 10:00 PM
timbersteel
Well, I swapped out my arm with the '95 project truck, that did not wipe well!!!
Missed 8" of spray sitting still. I'll have to swap the other arm from the project truck and see if maybe it's just a fluke. That arm from the project truck is bad from the passenger side is my guess. The truck hasn't ran since being bought, so I'll have to dig a little deeper.
Old 01-26-2016, 11:11 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
Personally I have never had any kind of luck with the newer style one piece flexible wiper blades on 80/90s trucks, they would never conform to the windshield and would tend to float at highway speed, The best luck I had with my trucks was to go down in size 2" with the old-style metal framed wiper blade.
Old 01-30-2016, 10:24 PM
jason90f150's Avatar
jason90f150
jason90f150 is offline
Take some rubbing alcohol and a terry cloth and soak the cloth and wipe the blades down. You'd be surprised of all the dirt on the rubber. May take 3-4 wipes to get clean. Once the rubber wiper is clean, you shouldn't have chatter. Even when I get new blades, I still clean them. Try it it works.
Old 01-31-2016, 02:32 AM
DeathRangerofDeath's Avatar
DeathRangerofDeath
DeathRangerofDeath is offline
Ditto. I tried every brand and style of wiper blade (and headlight bulb, but that's another thread) when I was getting them for cost. Every single one of them worked worse than the $4 anco blades.
Although twisting the arm has me intrigued. Hadn't thought of that. My driver side chatters a little bit now, chalked it up to the blade going bad. May have to try that.
  #28
Old 02-15-2016, 11:46 AM
aj88V's Avatar
aj88V
aj88V is offline
Hey, glad I popped back to this thread to report what I found. You guys have a ton of good info!
FWIW, I took the advice about bending the arm a little. Used an adjustable wrench to bend the flat part of the arm, holding it up near where the blade attaches. It's not perfect, but it is MUCH better. The bladed still doesn't wipe the water perfectly over the entire area (driver's side), but I was able to make it so the crappy area happens only on the lower portion near the end of the stroke (when the blade is near vertical) - way out of my field of view.
Amazing how sensitive the "wipe quality" is to the angle of that arm, but twisting it I got the bad spot moving in all different places. If you have this problem, it's definitely worth trying to twist the wiper arm a little.
Thanks again, guys. Great advice!
  #29
Old 02-15-2016, 02:37 PM
Bird-Dog 250's Avatar
Bird-Dog 250
Bird-Dog 250 is offline
Originally Posted by Bird-Dog 250
Like "Absloute" said it's not the pressure of the blade on the windshield. It's the ability of the blade to flip so the blade is dragged instead of being pushed in the direction of the wipe. It's a real dealer fix too to adjust the twist of the wiper arm and not the pressure. Having used this fix many times over the years I'd use an adjustable wrench instead of pliers. The wrench grab firmlywill not slip or gouge the wiper arm metal and you'll get a better twist, you won't have to squeeze and twist at the same time.
I'll quote myself on this once again...
Craig N
2017+ Super Duty
15
08-14-2019 01:01 AM
johnboggs21
17
06-06-2010 02:21 PM
firstford
02-19-2007 02:43 PM
rsylvstr
1997 - 2003 F150
01-19-2007 06:45 PM
Delaware04F-150
2004 - 2008 F150
10-31-2004 02:30 PM
Quick Reply: let's talk about wiper blades
