let's talk about wiper blades
The driver's blade didn't work well on my truck even though the rubber was still soft and flexible. I replaced both of them - think I used Anco blades - but the driver's side still leaves big blobs of water smack in the center while the passenger side works fine - just like before.
Maybe this has something to do with the curvature of the windshield?
Am considering buying a shorter blade and seeing if that helps. Stock is 18" for both blades, so maybe a 17" or even a 16" might help.
Or maybe try an expensive 18" silicone wiper blade?
Anybody else have this problem? What works for you?
I had a problem similar to this in my old 87 e250, for some reason the passenger side wiper base was at a weird angle and wouldn't hold the wiper against the window. Leaving a big gap where water would just sit. I ended up bending the lower part of the wiper arm so it angled it more toward the window. Don't know if that's your problem but it kinda sounds like it. Maybe pop the cowl off and take a better look, maybe something sagged in the mechanism on that side.
I've been fighting with the same problem off and on for years.
I use only Motorcraft blades due to the other brands chattering so badly.
What I don't understand is even with bending the arm, it still doesn't makena difference. The windshield was replaced in July 2014.
The problem is only on the driver side and is usually only affected at speeds above 30+ mph. The only thing I can think of is that the spring that pulls tension down is weak and allows for lift.
Here's a pic of a LMC wiper arm purchased 7+ years ago and the 24+ year old wiper arm spring from Left to Right.
I'm gonna attempt to change the length of the spring or look at the hardware store for a replacement.
Chattering was greatly reduced going with Motorcraft blades..no idea why, but I refuse to buy any other brand. Arms are interchangeable, they don't have to be specific to either side.
I just have that blob that doesn't get squeeged off on the driver side. I found a spring that is close to the OEM, so I changed it. I will know later once the snow quits. I don't know if you can purchase new arms from Ford or not. LMC has them and the arm on the left is a LMC arm.
The chatter is not caused by the arc of the arm, but the angle instead. Its twisted so its pushing the blade into the window. I'll bet it only chatters in one direction. Because when it goes back, its the opposite and slides. To fix, first you need to know whether it chatters going up, or down. If up, take your pliers and twist the arm, not bend, so that the blade turns slightly to the passenger side. So facing the truck, twist clock wise. If chattering on the way down, twist toward drivers side or counter clockwise facing the front of the truck. Might take a couple tries, but the sweet spot is pretty big, so easy to find. Basically the wiper is supposed to flip from side to side. If twisted incorrectly it will not slide in one direction because it doesn't flip all the way to one side. Like shoveling snow. Handle low and the shovel slides nice. Lift the handle up high the blade digs in and it jams to a stop. Just like your wipers. Except your wipers power threw and chatter instead of stopping. The shovel would too if you had more power and it didn't jab ya in the ribs and wind ya. Lol
Chattering is in the blades. Blades not completely cleaning the windshield is the arms. I've been bending my arms to get more pressure on the blades. I've tried a couple of different brands of arms and none of them are close to the original ones. I'm looking to see what timbersteel discovers!
I have found that using a windshield treatment like RainX helps with the chatter and cleaning of all of the water. But I shouldn't have to use it when everything is working right.
Finally bought new arms.........problem solved. No longer leaning sideways to see in the rain
The twist is definitely your issue. I use the cheapest blades out there. 6 bucks a pair, and a slight twist cured mine. Cresent wrench is a great idea to prevent scoring it up. Just make sure you use the metric one and not the imperial. The imperial doesn't quite fit right. Hahaha
