noisey hubs
noisey hubs
2004 f250 4x4 manual hubs. No noise when free wheeling with hubs locked in 2wd. pull lever down into 4x4 and get on the gas sounds like the hub is grinding apart pulled hubs apart and can't see any shinny spots where it might be slipping. cleaned the hub locking gears and still the same thing . New wheel bearing hub assy. and drive axle u-joints also. Hub is definitely locked.
Well found the culprit, everything in the front end was good, it seems their is a ball and socket thing in the driveshaft that went bad and caused the front drive shaft to loose a weight and between those two items was my growling noise and vibration so in the future it will go to driveline shop to get the associated parts replaced because we cannot get the ball and socket thing. In the mean time new front everything and good for another 12 years.
You said that 4X4 wasn't used much so you could not understand why the u-joints could be bad. You will find that all the 4X4 parts tend to last longer if they are used often. I leave my front hubs locked in from November until April every winter unless I am on a long (over a 100 miles) road cruise with no bad weather expected and put transfer case into 4-hi with hubs "free" at least once a week for 1/2 mile or so to keep everything free and lubed, u-joints don't like not moving, the grease hardens and then doesn't lube the joint causing premature wear when you do use it also the front differential gets lubed this way as well, I have seen front ring gears that just sat that were badly rust pitted on the top half that wasn't sitting in the lube in the bottom of the diff. By using 4-hi occasionally you coat the gears with a layer of oil to help preserve them.
