5.4 engine problem
5.4 engine problem
hi, guys i have a ford f250 with a 5.4l 2v engine and lately it started to shake when it idles. i have changed all the ignition coils and spark plugs, the injector are fine, but i cant seem to pinpoint the problem. the weird thing is that there are no codes. the fuel trim on bank 1 is around -8 and bank 2 is at almost positive 20 and higher. does anyone have any suggestions? thanks
My 5.4 2006 truck had similar issues with the fuel trims out of whack. It turned out to be the passemger cat was broken and plugged up. After changing the cats with high flow units the truck ran great. Just a suggestion. Put a pressure gauge in the O2 sensor 1 location if possible and take a reading while running. The pressure should be around 2psi or so for a good flowing sytem. Any higher indicates a restricted exhaust. Terry
If it's shaking it could be a bad fuel injector clip that attaches to the fuel injectors. The electrical clips that attach to the fuel injectors as well as the coil on plug connectors get brittle and break.
I had the same issue. It was a bad fuel injector connector.
Rent or borrow a noid light test kit. Unplug one by one and use the noid light to see if it lights up. You can rent a kit at autozone or orielly.
Good luck!
Good luck!
ok so i am here to report my findings. i have not found a solution yet but so far i have check exhaust back pressure which is good, not clogged, i also checked for vacuum leaks by spraying brake cleaner around the intake and i used smoke to see if there were any leaks. i could not find anything. the only thing i saw was that there was smoke coming out of the iac tube that connects to the intake hose before the throttle body. is that normal? the truck still hasn't given me any codes and its getting really bad gas mileage.
