Stuff i wanna fix: pics (secret button)
Old 01-17-2016, 10:55 AM
pkthomas's Avatar
pkthomas
pkthomas is offline
If you hit the 7/8 and 9/0 at the same time do the doors lock? If not it might be disconnected or broke.
Old 01-17-2016, 11:11 AM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
Good advise, easy test
Old 01-17-2016, 12:32 PM
jrockdiddy's Avatar
jrockdiddy
jrockdiddy is offline
I'll check shortly when I get off the freeway. I'll report back shortly
Old 01-17-2016, 02:53 PM
jrockdiddy's Avatar
jrockdiddy
Truck does not lock when I hit 7/8 and 9/0 at same time
Old 01-17-2016, 03:28 PM
LivingLarge
So you have an issue to find out before even getting the code...
Old 01-17-2016, 03:32 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
it washes my radio with static the moment I flip it on.
Makes me think the prior owner had an external XM receiver (or external audio source) which this switch controlled.. OR a signal jammer to annoy folks using their cell phones while driving...
Old 01-17-2016, 04:17 PM
05MilMachine's Avatar
05MilMachine
05MilMachine is offline
These keypads don't like to sit unused for long periods of time. When I don't use it for months on end the buttons can take time to clean off the contacts and start working. I sometimes have to press them harder when that happens. Since the lighting on mine still works, I know when i have a dead button. The keypad looks easy enough to replace and I will do that when the lights quit
Old 01-17-2016, 04:32 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
Maybe the secret to your switch is it disables the key pad
Fwiw.... That section of dash pops off fairly easy and quick if you want to trace the wires
Old 01-17-2016, 05:02 PM
El_Coqui's Avatar
El_Coqui
El_Coqui is offline
..OR a signal jammer to annoy folks using their cell phones while driving...
I wish it did....I may have to test that theory.....though I would much rather it activate a rocket launcher
Old 01-17-2016, 06:48 PM
jrockdiddy's Avatar
jrockdiddy
Just finished passenger front door lock. Works like a charm now. I freakin love FTE!! I'll try the secret button and then keypad. It does have touchscreen pioneer radio in dash...
Old 01-18-2016, 02:14 AM
jrockdiddy's Avatar
jrockdiddy
Just an update, tonight, when I pressed buttons on the keypad, the interior lights came on. Confusing... Any ideas?
Old 01-18-2016, 05:12 AM
Jointasset's Avatar
Jointasset
Jointasset is offline
Also, found a secret button. doesn't do anything when i flip it. any ideas? how do i find what it is wired to without pulling everything apart?
[/QUOTE]
The previous owners last name wasn't Bond was it? I wouldn't want to be sitting in the passenger seat when that thing finally decides to work.
  #28
Old 01-18-2016, 06:57 AM
Boatally Insane's Avatar
Boatally Insane
Boatally Insane is offline
I had one of those in mine too when I bought it !
Found that it turned on a P.A. speaker mounted under the truck hooked to the radio for playing mariachi music..
  #29
Old 01-18-2016, 09:40 AM
05MilMachine
That's normal system ops.
  #30
Old 01-18-2016, 09:54 AM
jrockdiddy's Avatar
jrockdiddy
Then why does it not lock when I press 7/8 and 9/0 same time?
Quick Reply: Stuff i wanna fix: pics (secret button)
