4.56 regear
4.56 regear
Hi, thanks for checking this thread out.
I am planning on regearing my truck. at the moment my rear end needs to be rebuilt. Not sure how extensive the damage is. But because of this I have an opportunity to regear my truck.
I have done a fair bit of research and i have decided i want to go with 4.56s. I have a 1990 4x4 f150 351w with an e4od. It has a 4" lift and will 33" tires. I may want to go up to 35s down the road some time.
My main questions are what exactly i will need for this. I think i want to buy the parts online and take it to a shop.
From what i have researched i will need the ring and pinion for the front and rear obviously. I have read that i will need a new carrier case for the front as well as master overhaul kit for the front and rear. Am i missing anything?
I was putting together a hypothetical list on Randys website. I attached a picture of the items i put in my cart.
I would really appreciate some help on this. I know this is an expensive upgrade and i would like to do it right the first time.
And if anyone one knows of a reputable shop in albuquerque new mexico that would be awesome!
I'm not sure about what all you need, but my first suggestion would be to first find the shop you will have do the work and then see what they think of you providing all the parts. Some shops don't like working that way and will either say no, give you grief, or charge you more. For some it won't be an issue, but find out before you're committed.
I'll also point out that this would be the ideal time to add a locker or Truetrac if you have any thoughts about that. It adds parts cost now, but the labor is free when you're already doing gears. And especially in the front where you need to buy a carrier anyway, you can buy a selectable locker instead.
The front you'd probably need a new carrier. The d44 has a carrier split, I believe 3.92 and up numerically and 3.73 and numerically lower. So if you already have 4.10 you would be alright, otherwise if you have 3.55 (most likely) or 3.73 you'll need it.
You might also look for thick gears instead of replacing the carrier. I guess they're becoming more common than they used to be.
The rear doesn't have this restriction.
You'll need gears, and master install kits ideally. That's all new bearings, new crush sleeves, usually shims and seals.
If you're that far into it, you may as well do the rear wheel seals and bearings too.
Thanks for the responses. I havent heard if thick gears i will look into them. Im guessing i would only need thick gears for the front because of the carrier. The truck has 3.55 so it will need a new carrier. The front already has a locker. I think its stock. Not really interested in locking the rear at this point.
This week i will call around town and see what the shops say in regards to me buying the parts.
For the front you'll need new carrier,ring and pinion,bearings..axle shaft seals,oil slinger and baffle probably
For rear new ring and pinion,carrier bearings,I recommend rebuilding the limited slip if your truck has it,and new wheel bearings and seals while its apart
I think almost any one could rebuild the rear if you can follow instructions,just make sure backlash is correct and torque to turn on pinion and your pattern look good
The front is just a little more difficult.
I rebuilt both of mine last summer.I have 4.56's with 35's
And if you do end up needing to replace the front carrier you'll be replacing whatever differential is there now. So you'll either need to buy a new open diff, a new limited slip, or a new whatever else you decide to put in.
But if you're happy with open diffs, that's fine. Just suggesting that you'll be kicking yourself a few years down the road if you end up needing to pay for all of the same work to be done a second time to install a different diff.
Ditto. A front locker is not for everybody. Most any limited slip would be good for basic mudding/forest roads and whatnot. If you get into offroading more than that you're going to want to ditch the TTB more than likely anyways.
