4.56 regear
Here's a link to a thread I wrote up on traction aiding diffs. It might help you
https://www.ford-trucks.com/forums/1...erentials.html
Summary: I'd never put anything other than a selectable locker (like an ARB) in the front. In the rear I'd go with a Truetrac for most street-oriented use, but would certainly consider an automatic locker if towing wasn't a big factor and I expected to be able to use the more positive traction. I'd also consider a selectable in the rear.
Wow thanks for all the info! I really have some more research to do considering the lockers. I would however prefer to keep the cost down as much as possible. And i am pretty interested in thw lunchbox lockers because of their affordability. But i do plan to keep the truck long term afer putting so much money into it. So i am also thinking of pissibly arb lockers at both ends.
This is what I did. I needed lower gears, which would have required a new carrier, so I went with lockers on both ends. Rear detroit, front ARB selectable. It takes some getting used to driving with a rear locker, but it's manageable once you get the hang of it.
Selectable front and rear is the best possible scenario, and is slightly more expensive, but just know that going with lockers isn't cheap to begin with.
I'll agree with some of what BruteFord said, and disagree with some. Don't put a lunch box locker (or any other automatic locker) in the front unless you will NEVER drive it in 4WD at any speed. They are DANGEROUS on snowy freeways.
In the rear a lunchbox locker is what, $200? And a Detroit is $450? (just guessing at the prices). As BruteFord said, the big savings in the lunchbox locker is in not having to pay someone $300 - $500 to set up the gears. You're doing that anyway. If you want an automatic locker I'd go with a stronger one now.
Where I differ from BruteFord is on clutch type limited slips. I'd much prefer to have open diffs, especially in the front. But that's my opinion.
An exception would be Panther chassis cars. They are 8.8s (some early ones were 8.2/ 8.5 variants), and 28 spline, with a 5 on 4.5" B.C. I believe in '05 or thereabouts they went to 30 spline axles.
In my rock crawlers I haven't had a front locker yet, so I can't say what I'd think of them. But I really like an automatic locker in the rear. I haven't thought it's hurt steering very much, and I really like the "automatic" part about it, not having to think about when to engage or disengage it. Plus, the time you need a locker the most is when you're climbing a hill. With more of the weight transferred to the rear axle it doesn't have as much less weight (or might even have more) than the front axle. So (without the experience of a front locker) I strongly lean toward a rear automatic locker in a rock crawler if there's only going to be one traction-aiding diff. (also better given the much higher likelihood of breaking an axle rock crawling)
Obviously there are other situations too, but those are the ones I'm familiar with, so those are the only ones I'll argue for.
....Edit, I should add that I would NEVER put a traditional locker in the front of any vehicle that might see any high speed driving with the front hubs locked. They are just too unpredictable as to when they will let go and how that will effect handling. I would however consider a spool/Lincoln lock. While they do effect handling at least its consistent and predictable which makes it manageable.
#28
