Brake Drum/Axle Mystery 1952 Dana 44
#62
Jim,
An after thought......I read another post regarding wear of the steel pads that the brake shoes rub against. I did not check these on mine before I reassembled my brakes.
Someone may be able to contribute the spec measurement to determine if they need to be built up on yours.
P.s. A short Bendix history: https://en.m.wikipedia.org/wiki/Bendix_Corporation
#63
I saw that 1955 date on a web page and I thought that seemed odd thanks for the redirect.
The left plate showed a little wear groove in the center. My right plate was is excellent shape so I used it.
I think we are good to go. When we get the truck on the road and Austin copes with what a 4.27 ratio is and how slowww it is I think we will do a retro with an 8.8 with discs and modify the front brakes to disc. But for right now we are going 100% original per Austin. If he maintains that all original code I will remove the drum and take a real good look at it after its used a little. .
#64
#65
The only problem I've ever had with the drum brakes on mine is getting them full of water or mud when I was younger. I don't know how many feet it takes to stop from 60 MPH, but it will squeal the tires without too much pedal pressure. - Bob
KRinAZ
04-02-2018 12:22 PM
Sycostang67
04-25-2013 10:11 PM
73f1004x4
18
06-03-2011 04:15 PM
