56 ford f100 rear end ?
There are a few unknowns in your statement...do you intend to mount the 4-link inside or outside the frame? Do you have a wheel/tire size in mind? The frame is 34 inches wide, the box is around 49 inches in width. This gives you about 7 inches on each side of the frame to tub out. Combine that with 10 inches of fender opening and you have a fairly sizable 17 inches on each side for tires. Here is a diagram I found from Art Morrison that may help:
iforeman
02-01-2013 06:54 AM
onelowzuki
01-10-2004 02:14 PM
jozs56ford
05-22-2002 08:53 PM
mather
05-03-2002 08:22 PM
