Mechanic doesn't recommend FW-16
#61
#62
#63
The only thing I can find like this is by Peak. It is pink in color. Is that the correct stuff?
#64
^^^^ Yes, Peak is now the parent company that makes FleetCharge, and it's dyed pink. Same stuff, new bottle. But WATCH OUT; like most anti-freeze, there's the full concentrate and the 50/50 pre-diluted. And the labels in this case are ALMOST the same. And as usual, buying the pre-diluted is just an expensive way of buying water. So make sure you get the full concentrate (and enough distilled water, of course).
#65
Yeah won't forget hat water again. One big mistake used tap water.... always have in the past with old Green. Never had any problem. Never tested either. Now I have a Diesel and did same thing. Tested way high in Acid on new antifreeze. Tested water from well and found it to be about 6.0...... Now I know better...after needing to throw out 4 gallons of new antifreeze.
