Stalling issue on my new 2003 Excursion.
The truck was just dropped off at my buddy's place. Looks like the the crank and cam sensors were replaced with oem sensors. I haven't touched it yet. I won't get out there until later this week. My friend started it and let it idle. Can the idle air control valve cause an intermittent stall condition?
The filter is changed. The tank will get dropped and checked. I might change the pump if need be. If the IACV is bad, will it be bad constantly or can it fail intermittently?
That's interesting. Fluid and filter changes will be the first things that I will do. I am just trying to get a jump on this stalling issue.
Low RPMs
- A bad idle air control valve will prevent adequate air flow to the engine and will result in increasingly lower RPMs when idling. The number of RPMs, while idling, will vary a bit based on the individual vehicle but is generally considered low when below 800 RPM. The RPMs will increase to normal levels when the accelerator is pressed.
- As the air control valve becomes increasingly clogged, the engine RPMs, while idling, will continue to drop until the vehicle stalls. This problem can usually be identified by applying the gas. When the vehicle is about to stall, pressing the accelerator will cause the RPMs to increase and will keep the car running. If the pedal is released, the RPMs will quickly drop, and the vehicle will stall. Sometimes, depending on how badly the idle air control valve is clogged, the vehicle may run correctly when the accelerator is pressed, but then sputter or stall when decelerating.
- If the idle air control valve has gone bad and no longer regulates the flow of air into the engine, typically due to the IAC being stuck open, the vehicle will idle roughly. A rough idle is characterized by shaking, vibrating and shuddering while the car is on but not moving. A rough idle due to a bad intake air control valve will eventually result in stalling immediately after starting the vehicle.
https://www.ford-trucks.com/forums/1...l#post10502511
Low RPMs
Low RPMs
Thanks for posting that up!
Better then how I would explain it! Plus I just saw this!
I drove it yesterday. I fired it up and let her run. No rough idle at any point. Before I took off, I used a can of starting fluid to spray down some of the hoses and around the engine to see if there are any vacuum leaks. No issues. I drove it down the road about a half mile and came back. I didn't want to go too far in case it stalled out. Nothing happened. So when I get some time I will change filters and fluids and check grounds. I don't want to replace parts unless I know they are defective.
Navigating180k
1997-2006 Expedition & Navigator
15
09-05-2013 10:28 AM
