Strong smell of diesel in exhaust.
Stock engine. I have noticed that after I installed the led mod to the glow plugs if I let the relay time out there will be enough white smoke to fill up my shop. There is a real real strong diesel smell. Also when it does crank it will clear up and there will be no visible smoke,but enough diesel fumes coming out the exhaust to burn your eyes. After running around town and stopping at a red light the fumes can be smelled after sitting there for a few seconds. What should I be looking at to solve this? Fuel mileage is still 14-15 miles per gallon.
Ok let me try to clarify. I know the led has nothing to do with it. I have had the odor since I got the truck 6 months ago. After installing the led I was trying to get in a habit of letting it time out approximately 2 min before attempting to crank the truck. The affects of this procedure has been a lot of white smoke and very strong diesel odor. It is as if the cylinders are loading up with a huge amount of diesel during that wait to start period and when I try to crank it it all comes out the exaust as raw diesel. Where would I start to look into fixing this. I do have AE.
Injectors won't fire off without the motor turning. Is is just in the exhaust or can you smell it under the hood? If it's in the exhaust, I think your injector(s) are leaking internally through the nozzle. It would be impossible to tell which ones without pulling them and bench testing them. Just to be sure, I would check under the hood smell around, smell the oil and coolant. If it's still in the exhaust, I think it's bad injectors.
Sounds like split nozzle or something. He said he could drive till warm and it still smells bad. To me that's raw fuel in the cyclinders or cyclinder that can't be burnt. You either have to pull them all and have them checked or maybe unplug one at a time drive it or let it run for a while and see if it clears up with that one unplugged. Me I'd pull them all one at a time and you mitt just find out which one it is, you mitt even find more then one that is bad.
