Need towing advice
Old 01-14-2016, 05:26 PM
dieselhead1052's Avatar
dieselhead1052
dieselhead1052 is offline
Originally Posted by tractoman
I have a 2" lift and use an 8" Curt drop hitch for my boat to keep it at the proper level. Depends on the trailer.
Okay. I'll wait till I pick up the trailer and then i'll measure.
Old 01-14-2016, 05:35 PM
modeltee's Avatar
modeltee
modeltee is offline
You will do fine towing in overdrive with your setup. I have the same year model truck as you but mine has 3.50 gears. The last camper I had weighed a little over 9000 lbs dry and I always pulled in overdrive when I could. On flat land I could run cruise control in overdrive but when pulling up marginal inclines I could not use the cruise control. It jumped in and out of overdrive too much. If you foot control the accelerator it will not go out of overdrive until it needs to. I remember one time being curious just how good my fuel milage would be in overdrive if I did not exceed 60 mph. It was hard to do that from several hundred miles but I wound up getting 14 mpg. I only did that once, seemed like it took forever to get to my destination. Yep, you won't have any issues pulling in overdrive.
Old 01-14-2016, 09:35 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
and cruise, forgot to mention that. I pull 17K all the time in cruise unless conditions don't allow it, love my cruise!!
Old 01-15-2016, 11:47 AM
dieselhead1052
Me too. Get on the freeway, Cruise at the speed limit in the slow lane. If I want to drive it like a sports car i'll get in my GLI..
zenish
Aerostar
07-09-2016 07:45 PM
lumprsmith F150
05-04-2010 05:52 AM
flyguy2
1997 - 2003 F150
07-13-2005 08:45 PM
javi2001
11-14-2004 06:52 PM
mikebll
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
02-26-2002 07:50 AM
Quick Reply: Need towing advice
