Bed roll repair
I've seen a TV show about making brass instruments where a series of progressively larger steel ***** were lubed and pressed through the tubing to round it out and expand it to size. This should be possible to imitate, maybe with a long piece of threaded rod made into a "puller" to force the ***** through the bed roll.
on
....Very carefully slice the damaged roll off with a die grinder/cutoff wheel. Try for the very top of the roll. Don't use a torch ... too much warp. Then weld on a piece of exhaust tubing of similar diameter. Mig welder, stagger your welds as to avoid over heating. Grind smooth, skim of filler, primer. ...........
Stan. ........
Stan. ........
If I was going to do the body work etc. Which I'm sure I will do eventually. I will do that probably. But looking to clean up the bad spots without welding grinding etc. My truck has 66 year old "paint" and will stay like that for a while so I can enjoy it a bit. When I build my shop I will do a complete resto/mod.
I know there have been some on here who have made there own bedsides(much easier to do on the 50 1/2 and up bed with the smooth sides) who have use tubing to weld on top of the bed bedside to mimic the original roll.
When I got my truck one of the bed sides had been slumped over for bout half of the length. I fabbed a lever to grab the bedside and was able to work it back into shape
Question I have is why are you talking about drilling and treading a ball? wouldn't it be better to have it free to roll? I also thought it would be better to split (cut) the top of the roll to allow you to pull and hammer the roll and then weld the slit back up after the rail is repaired
chris66
07-14-2013 09:00 PM
ben73058
02-09-2012 01:00 PM
spdmpo
1999 to 2016 Super Duty
04-23-2009 10:59 PM
