rideing down the road----wtf
Old 01-21-2016, 03:13 PM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
CLASSSSSSSS---CLASS--CLASS --FOCUS UP FRONT
next question--
before I did all the engine stuff-
I had to pull the trans to replace the flexplate----
so I could spine the motor with out it hittin the dead spot's
any way
this mourning the starter would not did-engage
what to do!!!!!---shims
  #62
Old 01-21-2016, 03:14 PM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
i cant start on the short bus till this f250 is done
and Friday 1 to 2 feet snow
  #63
Old 01-21-2016, 04:32 PM
madpogue's Avatar
madpogue
madpogue is offline
Oops, sorry about the
You sure that's not a starter issue? Sticking solenoid? Stuck relay? Wiring issue at the starter (cross between starter motor and solenoid wires)?
Or is it a case of the starter motor stops turning, but the bendix/gear remains extended?
  #64
Old 01-21-2016, 07:24 PM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
I don't know----
changed strarters today
did same thing
I cant tell if starter motor stops turning but Bendix is out--how do you tell?
been reading other post about fender relay
will try that tomoro
  #65
Old 01-23-2016, 09:31 AM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
this is what I found out--even with the Bendix all the way in -(and it does go in )
it still hit the gear ring---
so I shimmed it with 2 washers between starter and bell housing
on my --IDI- the starter has three bolting points-- this powerstroke-- only has two
sowwwww- when I shimed it the first time-- starter was not straight--- the second time I had to put 2 washers between starter and housing were a third bolt whould be--
started fine no more grinding------- did ford try to save money---one bolt at a time
  #66
Old 01-23-2016, 09:40 AM
farmert's Avatar
farmert
farmert is offline
The 2 bolt starter is for a superduty, but will work on the OBS. The OBS trucks left the factory with a 3 bolt starter.
  #67
Old 01-23-2016, 10:21 AM
madpogue's Avatar
madpogue
madpogue is offline
Are the two bolts you put in opposite one another by 180 degrees? Or did you just put in two bolts 90 degrees apart? Does the starter itself have three mounting holes?
  #68
Old 01-23-2016, 10:28 AM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
starter has only two--- housing has three holes
  #69
Old 01-23-2016, 10:30 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Then its a SD starter, I have one and it works fine.
  #70
Old 01-23-2016, 10:38 AM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
did you have to shim it-oldbird
  #71
Old 01-23-2016, 10:52 AM
oldbird1965
I took parts off my 8 track player and ..............LOL
NO, I didn't have to shim it. I got my starter from NAPA and it works good.
  #72
Old 01-23-2016, 12:56 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
There should be no need to shim the starter. You didn't put the flexplate on backwards did you????
  #73
Old 01-23-2016, 01:05 PM
madpogue's Avatar
madpogue
madpogue is offline
^^^^ Isn't there also a spacer in the mix there somewhere, with an auto? Wonder if parts got reinstalled in the wrong order.
  #74
Old 01-23-2016, 01:09 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
The spacer is 1" thick. It usually stays stuck to the end of the crank shaft when the flexplate comes off.
  #75
Old 01-23-2016, 01:22 PM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
the first thought that came to my mind---oh no I put the flex plate in wrong---
so I took the inspection cover off the short bus I just traded for---what a releaf
-its working now
just glad I was able to move the truck before this foot /half snow-- so I can snow blow drive way
and thank you all for helping
Thagodeus
06-29-2014 07:52 PM
garsm
02-20-2011 02:38 PM
ozutah
13
01-12-2011 07:48 AM
Nick18
15
06-22-2010 08:30 PM
2kcrewcab
02-25-2007 07:48 AM
Quick Reply: rideing down the road----wtf
