I need an adult - Ford Truck Enthusiasts Forums
I need an adult
Old 01-13-2016, 03:55 AM
Lauren Fortier Lauren Fortier is offline
Lauren Fortier is starting off with a positive reputation.
I need an adult
own a 1981 F-100 with a 300 inline six cylinder. The truck willl turn over but not start. I have checked the timing and it is okay. I have replaced ignition coil, plugs, wires, everything else has already been previously replaced.. even rebuilt the carburetor... has spark but will not start. It is getting fuel. It tries to start but wont. got her running on 3 separate occasions and she died within a week.. the odd thing is that the truck killed a brand new battery, but the alternator tested fine... I can't seem to find the problem. Help!
Thanks in advance
Old 01-13-2016, 07:00 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Quote:
Originally Posted by Lauren Fortier View Post
own a 1981 F-100 with a 300 inline six cylinder. The truck willl turn over but not start.... has spark but will not start. It is getting fuel. It tries to start but wont... the odd thing is that the truck killed a brand new battery, but the alternator tested fine... I can't seem to find the problem. Help!
You need three things for the engine to run; fuel, spark and compression.
Have you done a compression test?
Re: Your battery
Was the alternator tested for output only?
An alternator can have a bad diode and still produce power when turning.
There are a few 4.9 gurus here.
JimsRebel and 86F150six come to mind.
I don't think replying to a thread that's over 10 years old is likely to get you much help.
Old 01-13-2016, 10:46 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
When cold, is the choke plate completely closed? This would explain the engine not starting [if plate is closed hard], but not the fact that you had it running 3 times, but died within a week?
Starts when cold but not when hot - HELP NEWBIE! clowf350 6.0L Power Stroke Diesel 1 12-04-2015 09:36 PM
Starting issues with E450 Superduty bdfesq 1968-2013 Full Size Vans 12 03-29-2015 09:03 AM
Weird starting issues on 77 F-150 gcm4255 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-24-2015 06:20 PM
99 f150 4.2 crank but no start condition longacre5 1997 - 2003 F150 1 01-19-2012 03:40 AM
2004 f350 v10 no start...help gtmustang00 1999 to 2016 Super Duty 26 02-25-2008 08:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
