98 F150 airbag fault light - Ford Truck Enthusiasts Forums
Old 08-08-2003, 04:07 PM
bbgun bbgun is offline
bbgun is starting off with a positive reputation.
I have a 98 F150 and after a battery change I now have an airbag fault light on which seams to blink a code 25 or 2 & 5 with the ignition on then steady any suggestions????
Old 08-08-2003, 06:25 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
Its probably a code 52 which probably means you let the battery go dead or the charging system isnt working to full voltage. You can have someone with a scan tool reset it or in time it will stop on its own after so many key cycles I believe if the electrical system is working properly.
Old 08-08-2003, 09:52 PM
jonmech jonmech is offline
jonmech is starting off with a positive reputation.
There is no code 25 for that make and year,so Homerwinzlow is right about the code 52 which is loss of power or battery voltage is low.
Old 08-23-2003, 05:12 AM
CM113's Avatar
CM113 CM113 is offline
CM113 is starting off with a positive reputation.
ok but why would it blink a 2 4 code? i havent done anything to mine, it started doiing it when i was on vacation at hatteras [beach] and it doesnt do it every time just every blue moon, guys what does that mean?? i am the second owner of this truck , and as far as i can find out, it is a good truck has been so far except for this, thanks for any help you can give me
Old 08-23-2003, 05:52 AM
LFC 24/DTC B1342, B1924 System Disarm Fault or Air Bag Diagnostic Monitor is Faulted
Normal Operation
When the air bag diagnostic monitor detects a diagnostic trouble code (DTC) B1913 or B1914 fault, it attempts to disarm the air bag supplemental restraint system (SRS) by activating an internal solid state switch at Pin C209-13, Circuit 937 (R/W).
The activation of this switch shorts Circuit 937 (R/W) to ground, causing the power distribution box Fuse 2 (10 A) to open, disarming the SRS and preventing inadvertent air bag deployment.
WARNING: Do not under any circumstances substitute another fuse value for the power distribution box fuse 2 (10 a). Any fuse other than 10 a can cause disarming fault and can result in danger to the occupants of the vehicle. Do not attempt to replace the power distribution box fuse 2 (10 a) unless the battery ground cable has been disconnected and the backup power supply energy has been depleted. To deplete the backup power supply energy, disconnect the battery ground cable and wait one minute. Be sure to disconnect auxiliary batteries and power supplies (if so equipped).
The air bag diagnostic monitor will make up to three attempts spaced at one minute apart to open the fuse. If the attempt to open the fuse is successful, a DTC B1867 will be stored in memory. If the attempts to open the fuse are unsuccessful, a DTC B1924 will be stored in memory. After the power distribution box Fuse 2 (10 A) has been opened or three attempts to open it have failed, the air bag diagnostic monitor will not attempt to disarm the SRS again until DTC B1924 or B1913 has been repaired and cleared from memory.
The air bag diagnostic monitor also performs several self-tests every time the ignition switch is turned to the RUN position. If any of these tests fail, the air bag diagnostic monitor will flash a lamp fault code (LFC) 24. If any of these conditions later resumes normal operation, the DTC B1924 will be stored in memory.
The fault will either generate a DTC B1924 or B1342, depending on the cause of the fault. DTC B1342 is a special case DTC that will only be retrieved as a result of running the On-Demand Self Test. An intermittent B1342 cannot exist due to this fact. This DTC indicates that an internal microprocessor fault exists in the air bag diagnostic monitor. DTC B1924 covers the other internal air bag diagnostic monitor faults and is handled like any other DTC.
Possible Causes
System disarm fault or internal diagnostic fault can be caused by:
an improper fuse value in the power distribution box fuse slot 2.
excessive resistance or opens in the battery feed circuit due to corrosion, poor crimps, etc. The excess resistance could occur in the wiring at the air bag diagnostic monitor harness Pin C209-13, the 10 A power distribution box Fuse 2 terminal, or elsewhere in the battery feed circuit.
a vehicle charging system concern preventing the air bag diagnostic monitor from drawing enough current to perform its disarm.
an air bag diagnostic monitor fault of on-board diagnostic or system disarm.
resistance to ground in the normally open air bag sensor feed Circuits 617 (PK/O), 619 (PK/W), 624 (Y/W), and 625 (Y/LG).
Old 08-23-2003, 05:54 AM
You could also be mistaking a code 42 for a code 24
LFC 42/DTC B1942 LH Air Bag Sensor Feed/Return Circuit Open
Normal Operation
The voltage at Pin C209-15, Circuit 619 (PK/W), is set by the air bag diagnostic monitor to be slightly less than battery voltage. Circuit 619 (PK/W) is connected to Circuit 625 (Y/LG) inside the LH air bag sensor. Therefore, the voltage at Pin C208-23, Circuit 625 (Y/LG) should be the same as the voltage at Pin C209-15, Circuit 619 (PK/W).
The air bag diagnostic monitor periodically pulls the voltage at Pin C209-15, Circuit 619 (PK/W), low to verify the connection to Pin C208-23, Circuit 625 (Y/LG). If the voltage at Pin C208-23, Circuit 625 (Y/LG), does not pull low as a result of this test, the air bag diagnostic monitor will store in memory the diagnostic trouble code (DTC) B1942 and flash a lamp fault code (LFC) 42 on the air bag indicator. If the connection between Pin C209-15, Circuit 625 (Y/LG), and Pin C208-23, Circuit 625 (Y/LG), is later repaired, the DTC B1942 will be stored in memory.
Possible Causes
Failure to get low voltage at Pin C208-23, Circuit 625 (Y/LG), during the test can be caused by:
an open circuit in the wiring harness in either Circuit 619 (PK/W) or Circuit 625 (Y/LG).
an open circuit inside the LH air bag sensor across Circuit 619 (PK/W) or Circuit 625 (Y/LG).
a short to battery or ignition voltage in any of the Circuits 617 (PK/O), 619 (PK/W), 624 (Y/W), or 625 (Y/LG).
Old 08-23-2003, 10:04 PM
CM113's Avatar
thanks guys so i really need to change the fuse or go to auto zone and have the fault cleared?
Old 01-10-2009, 07:13 PM
sux2bu2day sux2bu2day is offline
sux2bu2day is starting off with a positive reputation.
Quote:
LFC 42/DTC B1942 — LH Air Bag Sensor Feed/Return Circuit Open
Normal Operation
Possible Causes
I've got a 2006 F-150, I'm getting an airbag light flash code of 42, would this be the same? I know this thread is over 5 years old, but it's worth a shot. I can't get the light to go off...
Old 01-10-2009, 07:21 PM
Quote:
That code on your 2006 is set when a front impact severity sensor fault is detected. Check that the mounting surface is clean (sand paint and rust under it if necessary) and the sensor is securely tightened down. If the code persists either a broken wire or connector issue exists or the sensor is defective. Ive had to replace a number of the sensors in the past. It is very easy to access, open the hood and it sits right there in the center of the condenser on a support bracket.
BTW air bag systems are warrantied for 5 years 50K miles.
Old 05-17-2009, 09:00 PM
rcdriver11 rcdriver11 is offline
rcdriver11 is starting off with a positive reputation.
97 f150
I am working with a 97 F150 I get code 42 flashing. Where would i look to repair this. If I reset the code will it come right back?
Old 05-17-2009, 09:15 PM
If you read a few posts up your answer is there.
Old 02-09-2013, 07:39 PM
vip3r82 vip3r82 is offline
vip3r82 is starting off with a positive reputation.
I am getting a 2-5 code on my 99 F150 as well. I was getting a code 2-7 but I fixed it and now getting this new code...
is the codes for a 98 the same for a 99 AB system?
Old 02-09-2013, 07:52 PM
No on your 99 flash code 27 indicated the bulb was not working on your passenger deactivation switch. Flash code 25 indicates that the switch is now faulting.
Aribag light on, after stereo install, no codes oft 1997 - 2003 F150 8 06-26-2016 11:53 AM
Airbags deployed NO accident f15098 1997 - 2003 F150 1 06-04-2016 06:56 PM
Airbag code 33 Flatbed79F250 2004 - 2008 F150 0 06-23-2015 09:34 AM
airbag trouble code mbowker64 1997 - 2003 F150 8 07-26-2010 11:24 PM
AirBag Light ibleedblueoval 1997 - 2003 F150 1 10-04-2009 12:35 AM
Tags
1998, 1999, 2001, 42, 52, air, airbag, bag, circuit, code, connections, f150, find, ford, light, open
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
