Front Driver-Side brake caliper
I'm a mechanical neophyte, but I am just really tired of being ripped off by the dealership. I have a stuck caliper that needs to be replaced and I'm trying to get the damn thing off. Can someone give me some pointers? I've tried prying, and using a C-clamp. Is it just a process of beating on it for a while? It moves around, but it just won't come off.
My thanks in advance.
In this video, the guy just pries it off with a flat-head. I wish it were that easy.
If I remember right, mine was a little tricky to get off too.
I used a strong screw driver like in the video and wiggled it in between the brake pad and the rotor until I could get the caliper off. If you can get a little room, move the screwdriver in a little further and it'll give you more surface area. It might be possible to damage your rotor though.
You can crack the bleed screw and it should make the piston easier to compress.
I don't remember needing to beat on mine to get them to come off.
I hope that helps!
I hope that helps!
This issue is common.
If caliper is stuck just remove the entire assembly, caliper and mounting bracket. Two bolts hold the bracket on to hub assembly.
Buy a new/rebuilt assembly that includes the bracket. Use the old stuck caliper and bracket for the core return and let someone else worry about how to seperate the caliper from the bracket.
http://m.advanceautoparts.com/mt/sho...=brake+caliper
If you're going to be replacing the pads, just pry against the pads to compress the pistons.
DaveTV
04-24-2014 07:33 PM
Mudd460
06-18-2009 05:01 AM
