RPM's reading wrong
RPM's reading wrong
When I start my truck the rpm's bounce alot as in 1000-2000 then slows to 1000-1200 then back to the big bounces truck doesn't have a cam or any power adders. This only happens on the gauge the truck doesn't fluctuate at all. 1990 f350 crew cab long bed 460 E4OD.
Could this potentially have any link to my trans not shifting properly?
on
On this vintage truck you simply have a bad tachometer, if you source another gauge cluster with a tach from an '88-91 V8 gas truck the tach portions will swap in without changing the whole cluster. You just have to remove the trim around the dash and cluster, remove the clear cover lense and then unplug the tach and swap it, easy 10min job.
If your truck also has trans issues pull the codes and post up what you get, that slushbox is 100% computer controlled and any code problem can result in strange trans behavour.
gixxxerrider600
02-16-2008 12:32 AM
