fuel filter changeouts
Mr. Murphy struck last night. Changed both fuel filters as I have done previously in the past. Accidently left the drain on the frame filter open a little. Did not prime the new filters the required 6 times. Engine will not start. How do I purge the air out and start the truck?
(2011 6.7 Diesel F-250). It is 15 Degrees F outside at the moment.
At this point, I'd consider 6 times the minimum. When I change mine out, I go by the sound. Or more accurately, the lack of air sound. If you listen, you will hear the frame rail pump run, and eventually shut off, which is roughly 30 seconds. that is 1 cycle. Do that as many times as it takes until you no longer hear air gurgling in the lines.
At this point, I'd consider 6 times the minimum. When I change mine out, I go by the sound. Or more accurately, the lack of air sound. If you listen, you will hear the frame rail pump run, and eventually shut off. that is 1 cycle. Do that until you no longer hear air gurgling in the lines.
Also, don't crank it too much. The HPFP isn't designed to operate dry.
You can now buy the Motorcraft fuel filters off Wal Mart for $55 plus tax with free shipping
Motorcraft Engine Fuel Filter, MTCFD4615 - Walmart.com
