2008 E250 LIGHTING
ROGHT SIDE PANEL
NO, I tired of wandering around in the dark n became a missionary.
The right side goes right on but comes off removing the doghouse.
Left side is more complex as I have 6'4" knees n top bottom width is minimal. Ifn ura short then probably remove the cushion panel n bolt scrap ply on left.
The right may have room for 7-8 switches
Yep...you know most technical articles have some kind of end-point in mind.
I have no idea what this thread is aimed at doing, or solving, or fixing.
It seems to be a moving target. Various statements about wiring and relays but I cant see where the thread is going. I clicked a few links but some of them went nowhere and drive-by malware is always a possibility with this type of thread.
I installed Hella H4 E-code headlamps and Rigid D2 LED driving lamps and I have a LOT of good quality forward lighting on low and high beams.
That's all folks!
That's all folks!
my system is obsolete on installation
1 amp
http://www.rallylights.com/philips-7-round-led-high-low-beam-dot-headlamp.html
thus, with 6 main bulbs n 2 minor cornering bulbs LED would pull 1 amp each equivalent to one 7x5 hi-lo halogen Hella.
