Smart Phone Holder / Bracket
I bought this just yesterday, fits 92-97 OBS F-Series. Then you just need the plastic holder.
FO-74-92
Even cheaper the FO-74-87 for the 87-91 models from this guy.
These all retail for $35+.
Check eBay or Google for others by searching "VSM" or "Pro.Fit" or "PanaVise" These are professional mounts, not shiken-chit Chinese crap.
FO-74-92
I use one of those sticky rubber pads for stuff you don't want to slide around. You would have to roll the truck over before it would fall off. If you have a CD player and don't use it much they have a mount that slides into the CD player slot. My sister has one, the phone is right at your finger tips and it's anice solid mount that removes as quickly as you can pull it out.
I have one for the cd slot, since I rarely use cd's anymore.
My phone fell out of it one time, but that's probably because I was driving across a very rough field through the snow....lol
The iOttie mounts are excellent. I have 4 of them now. They make several versions:
http://www.amazon.com/s/ref=nb_sb_no...s=iottie+mount
The rubber suction cup is better than anything I've found - it will even stick to the pebbled plastic dashboard, but I'd be afraid of long term discoloration. It will stay glued to your windshield and the mount adjustments hold tight, unlike cheaper mounts.
FO-74-92
FO-74-92
Maybe you could remove the plastic trim over the A-pillar by the windshield and make a little metal bracket the screws directly into the metal. Replace the trim and then attach the phone mount to the bracket you installed.
The phone mount like the iOttie works like gangbusters.
FO-74-92 Pro.Fit
It mounts using the two left heater control screws. It's only intended for automatic trans trucks and clearly states so. I figured the shift lever would cause this problem but I will modify it to fit the right side of the controls and it will be more perfectly placed, to me, than this factory version. You would still need the device specific holder but there are many accessories to go with this. I'm okay with my purchase.
The Pana-Vise 75107-393 would have been a better choice for me as it mounts under the dash trim strip.
FO-74-92 Pro.Fit
