why what went wrong with them.. did they tell you they needed changed.. did they explode or have bearing falure if they explode make certin they clean out the pipeing shrapnel left in inlets is bad news..
Umm what happened is that at first the oil will come uot from the turbo charcoals and then the withe smoke will come out.. After the power will reduce at least 80%
I will appriciate if you can tell me if i should just get new engine or perform ant kind of modificatio...
