Electrical Guru Question
In my 2000 F250 I have set up sleeping quarters in my camper shell. I have a fan, LED lights, and a few charging ports in back there. My original plan was to wire in a deep cycle battery the charges when the truck is running but disconnects when the truck is off so that I don't kill my starting batteries when camping. I have since ended up with some big gel cell batteries(C&D Technologies Long Duration Series TEL 12-70-BST). I took them by Interstate Batteries and spoke with them a bit. They said the batteries will be perfect for what I am doing with them but the alternators will charge at too high amperage and cook this battery.
Is there such a thing as an amperage reducer? What say the masses?
Ryan
Ryan
I suppose there could be such a thing but I don't know..How about you get an inverter! nice to have 120vac sometimes.. then you can get the proper charger for those batteries. now about only charging when the truck is running! you could wire up something to the key switch. you can use the inverter when ever you want...I'm guessing you need a gel cell charger/maintainer 2.0 amps...get the biggest converter you can afford. sine wave are better i think. Prob not neccesary though.
I am a little confused I was taught that the amperage drawn from the system is dependant upon the resistance of the device or devices connected to it. So if the alternator is working properly it will be running at 13.5 to 14.5 volts but the amperage draw would be determined by the batteries and the rest of the electrical system. I have a 300 amp HO alternator on my Ex but I don't have 300 amps passing through my trucks batteries or wiring. The truck/batteries draw the amps they need and is limited to what it can safely draw thru the fuses. A 12v battery shouldn't draw to much amps during normal charge unless the battery is extremely low 10 volts or less then it will draw higher amps until it reaches that 12v range again. But if I'm wrong please school me before I burn up my Ex!
Oh and to 99f350sd suggestion for the AC converter. It would be a helpful addition to that clean looking truck you have! It has been for my Ex for sure!
Inverter
I run a 2800w pure sine inverter with 4 100 amp/hr batteries off my f250 with no issues charging. I put in a 12v solenoid switched in the cab so i don't run main battery down. Also works if for some reason i let main battery get too low to start, i flip the switch and presto i can boost myself. Lol
I believe that somebody got amps and volts reversed. Unless one of your batteries has a shorted cell it will not draw too many amps, however gel cells don't like too high a voltage, that is why you can get an alternator with a lower voltage set point to avoid over charging gel cell type batteries. If I remember correctly you don't want over 14.4 volts when charging and about 13.3 on float charge.
Ryan
Ryan
Ending my novel, do not use deep cell batteries for starting, do not use starting batteries for campers, and isolate the two systems to ensure you do not run out of juice during your vacations!
