leveling 1970 f250 CS - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Log In
Old 01-10-2016, 08:40 PM
1browski 1browski is offline
1browski is starting off with a positive reputation.
Has anyone found any type of bolt on kit to raise the front of these trucks. It doesn't need to be level but 2 inches would be nice. Ive found coil spring spacers for about any truck besides these. This is not any top priority, its just on the wish list.
Old 01-10-2016, 09:42 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
It's more simple, in principle, to lower the rear than raise the front due to the induced camber change.
You really need to sit down and look at the front suspension and see what would happen.
Old 01-10-2016, 11:00 PM
I just got done looking at the front suspension. I see how even 2 inches would change the angle that the wheels hit the ground. I guess i was hoping it could be as easy as some of the little spacer kits that you see available for almost everything else. I don't think I want to lower the back. I think i like the high *** end better than bringing it down.
Old 01-11-2016, 12:00 PM
Alex from GA Alex from GA is offline
Alex from GA is starting off with a positive reputation.
Buy new front springs, the ones on are probably sacked and remove the rear leaves the po added for the camper.
Similar Threads
2009 6.4 limp mode Medic22358 6.4L Power Stroke Diesel 6 12-22-2015 02:28 PM
Leveling and Warranty Issues? bkuuz1 6.7L Power Stroke Diesel 2 08-27-2015 10:26 AM
Leveling kits and caster angle ? Grosjo Super Duty & Heavy Duty 0 09-04-2014 10:39 PM
1992 lift kit suggestions? SSBB 1987 - 1996 F150 & Larger F-Series Trucks 5 07-28-2014 12:18 PM
front end leveling buzzie0013 2007 - 2014 Expedition & Navigator 0 01-22-2014 01:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
